network driver (ac_enaddr) question
Feng, Shuchen
feng at bnl.gov
Fri Feb 20 22:05:01 UTC 2004
Hi all,
I had my ethernet hardware address copied to
the sc->arpcom.ac_enaddr in my network driver.
However, is this enough ? I mean :
if_attach(ifp) and ether_ifattach(ifp)
did not attach the ethernet hardware address
to the interface because :
ifp = &sc->arpcom.ac_if
Should I also had the MAC address copied
to the ifp->if_addrlist->ifa_addr (or a different
parameter)in my driver ? Or perhaps it is done
in a different layer of the RTEMS O.S ?
While tested with netdemo, the driver constantly
received packets in the Rx ring even though it is not
configured as "promiscuous mode" and I did not send
any packet. Perhaps it has something to do with the
broadcast ? Do I have to pass a broadcast address to
the networkconfig.h file if I supplied the IP address
instead of using BOOTP ? At this point, it seems
that the UDP transmit works fine.
Thanks,
Kate
