v4.6.0 make problem
Adriano Verardo
a.verardo at tecmav.fastwebnet.it
Wed Feb 25 19:19:30 UTC 2004
Hi, all
I'm trying to build v4.6.0 under Linux and FreeBSD 5.1 on i386 machines.
On both systems the configuration step goes OK but the compilation fails,
with the following output:
configure: configuring in i386
configure: running /bin/sh
'../../../../../../../rtems-4.6.0/c/src/lib/libcpu/i386/configure'
--prefix=/opt/rtems-4.6 '--prefix=/opt/rtems-4.6' '--host=i386-rtems'
'--build=i686-pc-linux-gnu' '--target=i386-rtems'
'--with-target-subdir=i386-rtems'
'--exec-prefix=/opt/rtems-4.6/i386-rtems'
'build_alias=i686-pc-linux-gnu' 'host_alias=i386-rtems'
'target_alias=i386-rtems' 'RTEMS_BSP=pc386' 'RTEMS_CPU_MODEL=i386_fp'
'RTEMS_BSP_FAMILY=pc386' 'CFLAGS_OPTIMIZE_V=-O4'
'--cache-file=/dev/null'
'--srcdir=../../../../../../rtems-4.6.0/c/src/lib/libcpu'
--srcdir=../../../../../../../rtems-4.6.0/c/src/lib/libcpu/i386
../../../../../../../rtems-4.6.0/c/src/lib/libcpu/i386/configure: line
1212: syntax error near unexpected token `RTEMS_TOP(../../../../..)'
1212: `RTEMS_TOP(../../../../..)'
configure: error: /bin/sh
failed for i386
'../../../../../../rtems-4.6.0/c/src/lib/libcpu/configure' failed for
lib/libcpu
The same configure/build procedure runs successfully for v4.6.0pre5 and
ss-20030703 with Linux and FreeBSD.
Any suggestion ?
Adriano Verardo
TECMAV srl
GENOA - ITALY
