About priority ceiling semaphores
Luís Henriques
lhenriques at criticalsoftware.com
Thu Feb 26 17:06:52 UTC 2004
Hi,
I'm using RTEMS v. 4.5.0 and I have a question about the use of priority
ceiling semaphores.
I have an application that creates two binary semaphores with the following
attributes:
* RTEMS_PRIORITY
* RTEMS_BINARY_SEMAPHORE
* RTEMS_NO_INHERIT_PRIORITY
* RTEMS_PRIORITY_CEILING
* RTEMS_LOCAL
Semaphore A has the priority ceiling set to 15 and semaphore B has the
priority ceiling set to 10.
Then, in a task, I obtain semaphore A (and the task priority is set
15). Later, still with semaphore A belonging to the task, I obtain
semaphore B (and the task priority is raised again to 10).
The question is: what should happen to the task priority after the
release of semaphore B? I was expecting that the priority would be set
to 15 again but what really happens is that it is maintained at 10 --
only after releasing semaphore A the priority is changed again.
Is this behaviour correct? Or is a problem (probably already fixed in
later versions) in RTEMS?
Thanks in advance.
Luís Henriques
