rtems_event_receive() return code question
Joel Sherrill
joel.sherrill at OARcorp.com
Mon Feb 2 19:43:58 UTC 2004
Thomas Rauscher wrote:
>>>>-----Original Message-----
>>>>From: Sergei Organov [mailto:osv at topconrd.ru]
>>>>Sent: Monday, February 02, 2004 6:13 PM
>>>>To: Thomas Rauscher
>>>>Cc: rtems-users at rtems.com
>>>>Subject: Re: rtems_event_receive() return code question
>>>>"Thomas Rauscher" <trauscher at loytec.com> writes:
>>>>>Hi,
>>>>>I've a question regarding the rtems_event_receive() semantics.
>>>>>The API documentation unfortunately leaves some open questions.
>>>>>If a rtems_event_receive() function is called with timeout, but
>>>>>receives events just while returning after a timeout, is it
>>>>correct to
>>>>>return RTEMS_TIMEOUT but have the event_out parameter set to
>>>>>a satisfying event set?
>>>>While not explicitly documented, the 'event_out' is left untouched
>>>when
>>>>RTEMS_TIMEOUT is returned. Thus, you need to initialize it to 0 before
>>>calling
>>>>rtems_event_receive() (it's almost always a good idea to
>>>>initialize all your variables anyway). Alternatively, check return
>>>code and don't
>>>>use 'event_out' when something other than RTEMS_SUCCESSFUL is
>>>returned.
>>>Well, in my case *event_out is always zero before being used.
>>>I think, that the code path I'm talking about, includes a race condition
>>>when the rtems_event_receive() caller actually is dispatched after
>>>waiting.
>>>Then the return code is RTEMS_TIMEOUT and 'event_out' is changed.
>>>At least I didn't see that the Wait.count variable of the waiting thread
>>>is set to zero by the _Event_Timeout() function, like it is done by the
>>>_Event_Surrender() function. This was added 2001 or so,
>>>as it fixes a bug when sending events from interrupt service handlers.
>>>Please correct me, if I'm wrong.
>>>BTW, I can happily live with a return code of RTEMS_TIMEOUT and set
>>>output events. I just wanted to make sure that this is the intended
>>>behavior.
>>It is not the intended behavior. If you get a non-successful status,
>>then there should be no events received.
>>Technically the timeout code may need to be more paranoid in the case
>>an event generating interrupt source nests the timeout code in the
>>clock tick ISR. So it might be worth considering, something like this:
>> _ISR_Disable( ... );
>> if ( the_thread->Wait.count ) { /* verify thread is waiting */
>> the_thread->Wait.return_code = RTEMS_TIMEOUT;
>> the_thread->Wait.count = 0;
>> _ISR_Enable( ... )
>> _Thread_Unblock( the_thread );
>> } else
>> _ISR_Enable( ... );
>>What about that for the else case in _Event_Timeout()?
> Great, this is what I've had in my mind when leaving
> the office. I'll test this code tomorrow.
Please file a PR with the fix and this will make the cut for
4.6.0. I am reviewing the getting started manual and
website for 4.6.0 and haven't finished yet. The final
4.6.0 tarball will be cut once that review is finished.
Also Ralf keeps using his keen power of observation and
finding things to fix so everything is perfect :)
[And I really appreciate that about Ralf. :-) ]
> Maybe I also can figure out a solution for the else case.
What is the problem with the else case except that it is
ugly to have to have the Enable nested?
> Many thanks,
> Thomas
> Dipl.-Ing. Thomas Rauscher Tel.: ++43 1 402 08 05 15
> Fax: ++43 1 402 08 05 99
> LOYTEC electronics GmbH E-mail: trauscher at loytec.com
> Stolzenthalergasse 24/3, A-1080 Wien Web: http://www.loytec.com
