rtems_event_receive() return code question
Thomas Rauscher
trauscher at loytec.com
Mon Feb 2 18:35:35 UTC 2004
On Mon, 2 Feb 2004, Joel Sherrill wrote:
> Thomas Rauscher wrote:
> >>-----Original Message-----
> >>From: Sergei Organov [mailto:osv at topconrd.ru]
> >>Sent: Monday, February 02, 2004 6:13 PM
> >>To: Thomas Rauscher
> >>Cc: rtems-users at rtems.com
> >>Subject: Re: rtems_event_receive() return code question
> >>"Thomas Rauscher" <trauscher at loytec.com> writes:
> >>>Hi,
> >>>I've a question regarding the rtems_event_receive() semantics.
> >>>The API documentation unfortunately leaves some open questions.
> >>>If a rtems_event_receive() function is called with timeout, but
> >>>receives events just while returning after a timeout, is it
> >>correct to
> >>>return RTEMS_TIMEOUT but have the event_out parameter set to
> >>>a satisfying event set?
> >>While not explicitly documented, the 'event_out' is left untouched
> > when
> >>RTEMS_TIMEOUT is returned. Thus, you need to initialize it to 0 before
> > calling
> >>rtems_event_receive() (it's almost always a good idea to
> >>initialize all your variables anyway). Alternatively, check return
> > code and don't
> >>use 'event_out' when something other than RTEMS_SUCCESSFUL is
> > returned.
> > Well, in my case *event_out is always zero before being used.
> > I think, that the code path I'm talking about, includes a race condition
> > when the rtems_event_receive() caller actually is dispatched after
> > waiting.
> > Then the return code is RTEMS_TIMEOUT and 'event_out' is changed.
> > At least I didn't see that the Wait.count variable of the waiting thread
> > is set to zero by the _Event_Timeout() function, like it is done by the
> > _Event_Surrender() function. This was added 2001 or so,
> > as it fixes a bug when sending events from interrupt service handlers.
> > Please correct me, if I'm wrong.
> > BTW, I can happily live with a return code of RTEMS_TIMEOUT and set
> > output events. I just wanted to make sure that this is the intended
> > behavior.
> It is not the intended behavior. If you get a non-successful status,
> then there should be no events received.
> Technically the timeout code may need to be more paranoid in the case
> an event generating interrupt source nests the timeout code in the
> clock tick ISR. So it might be worth considering, something like this:
> _ISR_Disable( ... );
> if ( the_thread->Wait.count ) { /* verify thread is waiting */
> the_thread->Wait.return_code = RTEMS_TIMEOUT;
> the_thread->Wait.count = 0;
> _ISR_Enable( ... )
> _Thread_Unblock( the_thread );
> } else
> _ISR_Enable( ... );
> What about that for the else case in _Event_Timeout()?
Great, this is what I've had in my mind when leaving
the office. I'll test this code tomorrow.
Maybe I also can figure out a solution for the else case.
Many thanks,
Thomas
Dipl.-Ing. Thomas Rauscher Tel.: ++43 1 402 08 05 15
Fax: ++43 1 402 08 05 99
LOYTEC electronics GmbH E-mail: trauscher at loytec.com
Stolzenthalergasse 24/3, A-1080 Wien Web: http://www.loytec.com
