unsigned long long working ?
Feng, Shuchen
feng at bnl.gov
Thu Feb 12 20:18:59 UTC 2004
Aaron J. Grier wrote :
> works fine on m68k. (the emitted assembly isn't bad either.) I even do
> (gasp) bit operations with them, and haven't had troubles with newlib
> misbehaving either.
Actually it worked fine on my 7455 and 604 PPCs as well. However,
I experienced the same problem as what Phil Torre described
about the formatted i/o functions (printf and friends) . The
workaround is to break down one 'long long' into two
'longs' for the printf and friends. I am using
the newlib-1.11.0. Perhaps you have a newer veriosn ?
Sergei Organov wrote :
> One thing that could bite you: gcc tends to use floating-point 64 bit
> registers (when compiles with -fhard-float) to move long longs (as well
as any
> other 64-bit entities) around. This could be a problem in FP-disabled
tasks. I
> use -fstrict-align switch to gcc that prevents gcc from using FP
registers
> from moving anything but floats/doubles. This behavior of the switch is
> neither documented nor guaranteed, but I don't know any other way to
achieve
> the desired effect.
I think Sergei meant -mstrict-align, not -fstrict-align. Correct ?
I did not find -fstrict-align in my GCC doc.
Thanks,
Kate
