some newbie questions
gregory.menke at gsfc.nasa.gov
Fri Feb 13 13:28:45 UTC 2004
sebastian ssmoller writes:
> hi,
> i am new to rtems. i looked around in the docs and sources and i find it
> really interesting.
> i am currently working in two projects using some developer board (ip
> 460) with a 68040 (host) and a 68360 (communication) cpu on it. further
> more these boards have CAN (controller area network) controller support.
> the more i look inside the rtems stuff the more i wonder whether it
> could be possible to adopt rtems for my needs.
Learning the RTEMS source is a fairly long process, you have to learn
a lot about it before you start to understand. If you can't find
something, please ask on this list.
> so could you please help me to answer some remaining questions (or
> just point me to the right place in your documentation set):
> - how do i install rtems on the target plattform ? i currently use
> serial line.
That entirely depends on the capablities of the target platform. If
your target has a boot monitor that can use a serial port to download
an image in some way, that will work. If it can manage a network
interface, it might be able to tftp the image- which is lots more
convienent (and faster).
> - is it possible to write and use my own scheduler ?
I suppose- but why? RTEMS's is very configurable and very bug-free.
If you want to add a new scheduling algorithm or modify one, make a
more detailed proposal and we all can comment on where/how and how
difficult it might be.
> - how difficult would it be to add CAN Controller support to rtems ?
A user-space driver would be easiest- meaning you integrate the driver
with your project code and call it directly. Further integration into
RTEMS depends largely on what you want it to do.
> - what requirements does rtems have ? (disk ?, memory ?)
The OS image footprint ranges from ~100k up to several hundred,
depending on what you compile in. Your code adds to that of course.
There is no disk footprint as such on the target. The cross-compiler
suite and development libraries can consume a good bit on the
development host.
Gregm
