cexp and loadable modules
Till Straumann
strauman at SLAC.Stanford.EDU
Tue Feb 17 18:01:13 UTC 2004
sebastian ssmoller wrote:
> hi,
> i read something about dynamically loadable modules and rtems and i
> found "cexp". as far as i understand it, it is a shell-like prog which
> allows one to dynamically load modules into a prog(rtems) on runtime,
> right ?
> if so: is it really a "shell" ? i mean is it necessary that a user types
> the regexps and the load-module commands ?
There is an API and also a simple scripting feature (you can recursively
invoke the interpreter on a file).
http://www.slac.stanford.edu/~strauman/rtems/cexp
HTH
-- Till
> is there an API available so that u could write a program which is able
> to download a specified file and load it as new task into rtems ? (like
> kernel modules in BSD or Linux)
> thx,
> regards,
> seb
