volatile in struct
Chris Johns cjohns at cybertec.com.au
Wed Feb 18 13:26:03 UTC 2004
Juergen Zeller wrote:
> Can anyone out there explain whats going on here? I never thought that
> volatile could be responsible for errors. Is it because it's inside a
> struct?
> I think I know the meaning of volatile and this is what you discussed.
> But how can it be that the use of volatile is more faulty than without?
Maybe it would help if you could post a more specific example of the
code that shows the problem you are seeing.
  Chris Johns, cjohns at cybertec . com . au
