Help building gdb
David Querbach querbach at realtime.bc.ca
Thu Feb 19 17:09:26 UTC 2004
On Thu, Feb 19, 2004 at 08:27:52AM -0000, Stevens Brian wrote:
> I am trying to build a cross development system as follows:-
> 	Host:	GNU/Linux (Mandrake 9.2 on an AMD K6)
> 	Target	i386-pc
> When I try to build gdb I get an error reporting that it was unable to find
> a term library and it appears to have been searching for  a file called
> tgetent.
You need libtermcap and its sources.  According to the Debian documentation,
the best way to get these nowadays is to install the ncurses libraries and
sources.
I've found that when I install the ncurses source (Debian ncurses-dev
package), the gdb configure script makes the proper adjustments and gdb
builds and runs properly.
Regards,
David Querbach
Real-Time Systems Inc.
www.realtime.bc.ca
Name: not available
Type: application/pgp-signature
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20040219/3ceab079/attachment-0001.bin>
