Help building gdb
Joel Sherrill
joel.sherrill at OARcorp.com
Thu Feb 19 12:11:00 UTC 2004
Stevens Brian wrote:
>I am trying to build a cross development system as follows:-
> Host: GNU/Linux (Mandrake 9.2 on an AMD K6)
> Target i386-pc
>When I try to build gdb I get an error reporting that it was unable to find
>a term library and it appears to have been searching for a file called
>tgetent.
>The rest of my environment seems to be working as I have built the Hello
>World test and booted it via grub, but I need to get the debugger going.
You appear to be missing some development package.
rpmfind.net is usually a good starting point. You can search for which
RPM has the library in it
and then find the appropriate RPM for your distribution.
--joel
>Thank You
>Brian Stevens
>QinetiQ
>Cody Technology Park,
>Ively Road,
>Farnborough,
>Hampshire
>GU14 0LX .
>UK
>Telephone (01252) 393959
>Fax (01252) 395120
>The Information contained in this E-Mail and any subsequent correspondence
>is private and is intended solely for the intended recipient(s).
>For those other than the recipient any disclosure, copying, distribution,
>or any action taken or omitted to be taken in reliance on such information
>is prohibited and may be unlawful.
>Emails and other electronic communication with QinetiQ may be monitored.
>Calls to QinetiQ may be recorded for quality control,
>regulatory and monitoring purposes.
