some newbie questions
sebastian ssmoller
sebastian.ssmoller at gmx.net
Thu Feb 19 19:10:18 UTC 2004
hi,
finally i used the approach: incrementing a variable an see where it
stops.
> Seb,
> Just reset the board (don't powercycle). In most cases this doesn't
> corrupt memory. Usually, assuming you have a reset or NMI type
> of button, you can get yourself back to the monitor, then in RAM
> space you essentially have the equivalent of a core dump.
i did so and it worked perfectly well.
i started debugging at c/src/lib/libbsp/m68k/gen68360/start/start.S
where the start symbol which i call is defined. i found out that the
board hangs immediately at step 4 where mbar is set.
* Step 4: Write the MBAR
movec dfc,d1 | Save destination register
moveq #7,d0 | CPU-space funcction code
movec d0,dfc | Set destination function code register
movel #m360+0x101,d0 | MBAR value (mask CPU space accesses)
/* with the execution of the next line the board will hang */
movesl d0,0x3FF04 | Set MBAR
movec d1,dfc | Restore destination register
the original addr of the MBAR was 0x3ff00 as described in the 68360
manual (which failed). i read again the doc of my board and it says that
MBAR is at 0x3ff04. so i changed the value but nothing happens - the
board still hangs :(
thx
regards,
seb
Microsoft: Where do you want to go today?
Linux: Where do you want to go tomorrow?
FreeBSD: Are you guys coming or what?
OpenBSD: Hey guys you left some holes out there!
