Build problem with "or32" target tools - further info
Paul Cadaret
rtems at usd.com
Fri Jan 2 22:42:08 UTC 2004
Hello,
In regard to the problem I am having building the GNU tools for a 'or32'
target on Solaris-7 I decided to take another approach and I wanted to
report the results I have had.
I decided to try the 'RTEMS Download Helper'. I picked:
current snapshot
OpenRisc32
Solaris/Sparc
x-Tool Source
x-C++ Binaries
This generates the following URL:
http://www.rtems.com/cgi-bin/dl-helper?version=snapshot&target=or32&host=solaris&want_toolsrc=on&want_cxx=on
In the 'Tool Source' section the page shows the following links:
ftp://ftp.rtems.com/pub/rtems/snapshots/c_tools/LATEST-BINUTILS/source/binutils-2.13.2.1.tar.bz2
ftp://ftp.rtems.com/pub/rtems/snapshots/c_tools/LATEST-GCCNEWLIB/source/gcc-3.2.3.tar.bz2
ftp://ftp.rtems.com/pub/rtems/snapshots/c_tools/LATEST-GCCNEWLIB/source/gcc-3.2.3-rtems-20030507a.diff
ftp://ftp.rtems.com/pub/rtems/snapshots/c_tools/LATEST-GCCNEWLIB/source/newlib-1.11.0.tar.gz
ftp://ftp.rtems.com/pub/rtems/snapshots/c_tools/LATEST-GCCNEWLIB/source/newlib-1.11.0-rtems-20030605.diff
The important point here is that it appears that the tools I am supposed
to use are in the:
LATEST-BINUTILS and LATEST-GCCNEWLIB directories.
I then performed the following:
- downloaded all of the files,
- unpacked binutils
- Configured, built, & installed binutils for the or32-rtems target
; worked OK
- unpacked gcc
- applied gcc patches
- unpacked newlib
- applied newlib patches
- created symlink in gcc source tree to newlib subdir in the
unpacked & patched newlib source tree
- ran configure in my gcc build dir
(.../LATEST-GCCNEWLIB/gcc-3.2.3/build.or32-rtems)
'configure' was invoked as:
+ /bin/sh ../src/configure --prefix=/tools/local.or32-rtems
--target=or32-rtems --program-prefix=or32-rtems- --with-gnu-as
--with-gnu-ld --with-newlib --verbose --enable-threads
--enable-languages=c,c++ --disable-nls
It died the same as before:
checking whether times is declared... yes
checking for struct tms... yes
checking for clock_t... yes
checking if mkdir takes one argument... no
Configuration or32-unknown-rtems not supported
<<<================ Note
Configure in
/sd/c0t8d0/opt1/web/sites/ftp.rtems.com/tools/LATEST-GCCNEWLIB/gcc-3.2.3/build.or32-rtems/gcc
failed, exiting.
As with my previous post, any guidance here would be appreciated.
Thanks much.
Paul
