Fw: RTEMS - Image Loading problem for MIPS thru MAJIC
mansoor
mansoor at isofttech.com
Sun Jan 4 11:06:06 UTC 2004
HI
I built the RTEMS hello.exe using the mips-rtems toolchain. Iam using
rtems-4.6.0pre5 source configured
for our board (MIPS lx4189 r3000 based core).
Iam using EPI MAJIC to load the image the to the target.
When I tried downloading the hello.exe image to the target, MAJIC
continuosly throws
the following errors.
ERROR, input record not processed:
STAB 21 LSYM 00000000 0 "complex float:t18=R3;8;0;"
STAB 22 LSYM 00000000 0 "complex double:t19=R4;16;0;"
STAB 23 LSYM 00000000 0 "complex long double:t20=R4;16;0;"
I started my porting work with the jmr3904 BSP as base and iam using the
same rules for my target.
Also, for the same board we have ported linux using mips-linux toolchain
(gcc 2.95.3 as base).
Iam successfull in loading linux image thru EPI MAJIC.
What could be the problem ???.
> Thanx in advance
> Mansoor Ahamed Basheer
