termios task driven
Mike Siers mikes at poliac.com
Tue Jan 6 17:45:36 UTC 2004
Hi,
The highest baud rate that I tested pppd with was 57600.
So I would first check to ensure it works correctly at
this baudrate.
The other thing I would look into would be your task priorities.
I do not remember what priority the pppd task is started with.
Somewhere in the rtems source tree there is a sample pppd
application.  Have you tried running this application on your
hardware at the higher baud rate?
Hope this helps,
Good Luck
Mike Siers
-----Original Message-----
From: Sylvain Prestavoine [mailto:sylvain.prestavoine at memobox.fr]
Sent: Tuesday, January 06, 2004 11:30 AM
To: rtems-users
Subject: Re: termios task driven
----- Original Message -----
To: "Stan" <zylog at club-internet.fr>
Cc: "rtems-users" <rtems-users at rtems.com>
Sent: Tuesday, January 06, 2004 5:16 PM
Subject: RE: termios task driven
> Hi Stan,
> If I remember correctly, TERMIOS_TASK_DRIVEN mode is no
> longer required for pppd.
> Mike Siers
All right.
 But, why I tryed to use termios without this mode isn't work
 properly with great speed ( as 115200 bauds ) ?
An idea ?
Stan.
!DSPAM:3ffaf13681818263718276!
