termios task driven
Stan zylog at club-internet.fr
Wed Jan 7 17:08:29 UTC 2004
> ----- Original Message -----
> From: "Mike Siers" <mikes at poliac.com>
> To: "Sylvain Prestavoine" <sylvain.prestavoine at memobox.fr>
> Cc: "rtems-users" <rtems-users at rtems.com>
> Sent: Tuesday, January 06, 2004 6:45 PM
> Subject: RE: termios task driven
 > Hi,
> The highest baud rate that I tested pppd with was 57600.
> So I would first check to ensure it works correctly at
> this baudrate.
 > The other thing I would look into would be your task priorities.
> I do not remember what priority the pppd task is started with.
> Somewhere in the rtems source tree there is a sample pppd
 > application.  Have you tried running this application on your
 > hardware at the higher baud rate?
 No, for the moment, I put termios to the test only ( without pppd ).
 At the higther baude rate ( > 38400 bauds ), my application don't work
 properly.
 Have you tried running pppd with 115200 ?
 Which bsp have you ?
 Thanks.
 Stan.
