Workspace usage trouble
Cedric Aubert
cedric_aubert at yahoo.fr
Fri Jan 16 11:19:01 UTC 2004
Hi all,
I have some trouble with my workspace size. All work
fine when I put some
wrong number of task or semaphore or file dexcriptors
but when I put the
real number (with some upper number for task semaphore
and file descriptor)
that's don't work, it can't open allocate some task or
other object in the
workspace.
So how can I see the available memory left in
workspace ?
How can I known witch object use the workspace ?
What I missed to specifie ?
I take a look in the condefs but it seem to have
nothing forgotten.
Thanks a lot
Cedric
/* configuration information */
#include <bsp.h>
#include <Task.h>
#define CONFIGURE_TEST_NEEDS_CONSOLE_DRIVER // Use
console
#define CONFIGURE_RTEMS_INIT_TASKS_TABLE // Utiliser
la table Init Task
plus bas
#define CONFIGURE_MAXIMUM_TASKS 53 // 32 SDEL
Task and 1 RTEMS Init
Task
#define CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES 10
// Nombre de MailBox
#define CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS 3
// Signal
#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 300
// Nombre Max de
File Descriptor
#define CONFIGURE_MAXIMUM_SEMAPHORES 500 //
Nombre Max de Semaphore
#define CONFIGURE_NUMBER_OF_TERMIOS_PORTS 12 //
Nombre Max de Port
Serie
#define CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM // A la
place de MiniIMFS pour
avoir le support des link
// #define CONFIGURE_MEMORY_OVERHEAD 500
// Ko suplementaire
#define STACK_CHECKER_ON 1 // Activation du
Stach Check
#define CONFIGURE_INIT
rtems_task Init(rtems_task_argument)
/* Starting Application */
* The user is defining their own table information
and setting the
* appropriate variables.
#define CONFIGURE_HAS_OWN_INIT_TASK_TABLE
#ifdef CONFIGURE_HAS_OWN_INIT_TASK_TABLE
#undef CONFIGURE_INIT_TASK_NAME
#define CONFIGURE_INIT_TASK_NAME
rtems_build_name( 'm', 'a', 'i',
'n' )
#undef CONFIGURE_INIT_TASK_STACK_SIZE
#define CONFIGURE_INIT_TASK_STACK_SIZE
RTEMS_MINIMUM_STACK_SIZE // 0x6000
de place laissé par FBUG
#undef CONFIGURE_INIT_TASK_PRIORITY
#define CONFIGURE_INIT_TASK_PRIORITY 1
#undef CONFIGURE_INIT_TASK_ATTRIBUTES
#define CONFIGURE_INIT_TASK_ATTRIBUTES
RTEMS_DEFAULT_ATTRIBUTES
#undef CONFIGURE_INIT_TASK_ENTRY_POINT
#define CONFIGURE_INIT_TASK_ENTRY_POINT Init
#undef CONFIGURE_INIT_TASK_INITIAL_MODES
#define CONFIGURE_INIT_TASK_INITIAL_MODES
RTEMS_PREEMPT
#undef CONFIGURE_INIT_TASK_ARGUMENTS
#define CONFIGURE_INIT_TASK_ARGUMENTS 0
#ifdef CONFIGURE_INIT
rtems_initialization_tasks_table
Initialization_tasks[] = {
{ CONFIGURE_INIT_TASK_NAME,
CONFIGURE_INIT_TASK_STACK_SIZE,
CONFIGURE_INIT_TASK_PRIORITY,
CONFIGURE_INIT_TASK_ATTRIBUTES,
CONFIGURE_INIT_TASK_ENTRY_POINT,
CONFIGURE_INIT_TASK_INITIAL_MODES,
#endif
#define CONFIGURE_INIT_TASK_TABLE Initialization_tasks
#define CONFIGURE_INIT_TASK_TABLE_SIZE \
sizeof(CONFIGURE_INIT_TASK_TABLE) /
sizeof(rtems_initialization_tasks_table)
#endif /* CONFIGURE_HAS_OWN_INIT_TASK_TABLE */
#include <confdefs.h>
Cedric AUBERT
Ingenieur Recherche et Developpement
SDEL Controle Commande
D2A - Rue Nungesser et Coli
44860 Saint Aignan de Grand Lieu
FRANCE
Tel : +33 (0)2 40 84 50 00
Poste : 5109
Fax : +33 (0)2 40 84 51 10
E-mail : cedric_aubert at yahoo.fr
Web : http://www.sdelcc.com
__________________________________
Do you Yahoo!?
Yahoo! Hotjobs: Enter the "Signing Bonus" Sweepstakes
http://hotjobs.sweepstakes.yahoo.com/signingbonus
