Unhandled exception while running samples
durai
durai at isofttech.com
Mon Jan 19 06:05:25 UTC 2004
Hi all,
CPU - MIPS R3000 core (LX4189)
RTEMS-4.6-pre5
When I run the ticker and hello sample applications in my board, I am
getting an Unhandled exception at the end of execution (ie, after executing
all statements in the Init() functions, it throws the exception).
------------------------ crash dump --------------------
TA1 - rtems_clock_get - 09:00:00 12/31/1988
TA2 - rtems_clock_get - 09:00:00 12/31/1988
TA3 - rtems_clock_get - 09:00:00 12/31/1988
TA1 - rtems_clock_get - 09:00:05 12/31/1988
TA1 - rtems_clock_get - 09:00:10 12/31/1988
TA2 - rtems_clock_get - 09:00:10 12/31/1988
TA1 - rtems_clock_get - 09:00:15 12/31/1988
TA3 - rtems_clock_get - 09:00:15 12/31/1988
TA2 - rtems_clock_get - 09:00:20 12/31/1988
TA1 - rtems_clock_get - 09:00:20 12/31/1988
TA1 - rtems_clock_get - 09:00:25 12/31/1988
TA3 - rtems_clock_get - 09:00:30 12/31/1988
TA2 - rtems_clock_get - 09:00:30 12/31/1988
TA1 - rtems_clock_get - 09:00:30 12/31/1988
Unhandled exception 9
sr: 0x0000FF00 cause: 0x00000024 --> Breakpoint
R_RA 802010E0 R_V0 00000020
R_V1 B9020014 R_A0 00000000
R_A1 80222CD0 R_A2 80248ED4
R_A3 00000004 R_T0 0000FF01
R_T1 0000FF01 R_T2 DFFF00EA
R_T3 00000001 R_T4 FFFFFFFE
R_T5 FFFFFFFE R_T6 80222E28
R_T7 00000009 R_T8 FFFFFFFF
R_MDLO 0000012C R_MDHI 00000000
R_GP 80228DB0 R_FP FFFFFFFF
R_AT B9020000 R_EPC
80200068
The EPC shows 80200068, from the disassembly I can find sys_exit is located
there.
80200068 <_sys_exit>:
80200068: 03ff000d break 0x3ff
8020006c: 00000000 nop
80200070: 1000fffd b 80200068 <_sys_exit>
80200074: 00000000 nop
Should I implent the handler for software break?
regards
durai
