rtems Debugging
durai durai at isofttech.com
Tue Jan 27 06:21:06 UTC 2004
Hi,
CPU - MIPS R3000 core (LX4189)
RTEMS-4.6-pre5
I have compied rtems source with -g and -O2 gcc options.
I am using  EPI MAJIC JTAG debugger for debugger. When I debug the
executables I am not able to find the source code.
I have tested some elf files produced by the mips-linux-gcc compiler and the
debugger displays the source code .
The problem exists with the ELF files produced by the RTEMS. I saw a similar
post in the mailing list, but I am not able to draw any solutions from that.
Anybody tried mips-rtems-gdb for debugging?  Is mips-rtems-gdb is tested?
regards
durai
Confidentiality Notice
The information contained in this electronic message and any attachments to this message are intended for the exclusive use of the addressee(s) and may contain confidential or privileged information. If you are not the intended recipient, please notify the sender at mailadmin at isofttech.com immediately and destroy all copies of this message and any attachments.
