termios with high baud rate...
Charles Steaderman charlies at poliac.com
Thu Jan 15 20:30:24 UTC 2004
I have a custom 5206e board working with 60096 baud with interrupt based
termios, although the data from the sending device is not entirely
continuous. I will see if I can find a way to quickly modify my
application to test at 115200. How are you sending a continuous stream?
I am sure that hardware handshaking will be necessary. Is that OK for
your application?
- Charlie
Stan wrote:
>Hi,
>Does anyone use termios at 115200 bauds ?
>I would like to know it work properly on mcf5206elite...
>In my case, at this baud rate, with or without flow control,
>I don't receive characters if the flow is continuous :(
>It works only with a transmit delay between each line ( 1 ms ).
>If anyone can test it...
>Thanks.
>Stan.
>!DSPAM:4006ca5e145081831118914!
Charlie Steaderman
VP Engineering
Poliac Research Corporation
Phone: 952.707.6245
Cel: 612.242.6364
