termios with high baud rate...
Stan zylog at club-internet.fr
Fri Jan 16 14:14:52 UTC 2004
----- Original Message -----
From: "Charles Steaderman" <charlies at poliac.com>
To: "Stan" <zylog at club-internet.fr>
Cc: "rtems-users" <rtems-users at rtems.com>
Sent: Thursday, January 15, 2004 9:30 PM
Subject: Re: termios with high baud rate...
> I have a custom 5206e board working with 60096 baud with interrupt based
> termios, although the data from the sending device is not entirely
> continuous. I will see if I can find a way to quickly modify my
> application to test at 115200. How are you sending a continuous stream?
I send a text file with one terminal (PC).
> I am sure that hardware handshaking will be necessary. Is that OK for
> your application?
> - Charlie
My application is a simple buffer.
It must to work without hardware handshaking ( at least at 57600 ).
The 5206e ColdFire is fast ( 50 Mhz ),  it should be fast enough
for do it.
Stan.
