UDP error
    Ian Caddy
    ianc at microsol.iinet.net.au
    Fri Jul  9 01:56:49 UTC 2004
Hi,
The if_stats and mbuf_stats can be called at anytime and will print out
the statistics to your default console, I assume you have one of these.
Depending on how quickly you get this no buffers error, I would setup a
test task (or use one that is already in a loop) that called these
functions every x seconds (minutes, depending on time between errors).
You could then see how your buffers were progressing.
Once you get the no buffers error, it is too late to see as you know you
have none left.
In this way you can see if you have a gradual buffer problem, with you
constantly having less buffers, or something happens to sort of make
everything stop and suddenly you run out of buffers.
Talk to you soon,
Ian Caddy
Angelo Fraietta wrote:
> Thomas Rauscher wrote:
>> If this error occurs, try dumping the IP interface and mbuf statistics
>> to find out where the limit is.
>> rtems_bsdnet_show_if_stats();
>> rtems_bsdnet_show_mbuf_stats();
> Do I do this when the error orrcurs? My application does not have a
> keyboard input.
>> Did you set the SO_BROADCAST option on your sending socket?
>> I think I needed this:
>>   int broadcast = 1;
>>   if(setsockopt(fd, SOL_SOCKET, SO_BROADCAST, &broadcast,
>> sizeof(broadcast)) != 0)
>>     printf("setsockopt failed: %s!\n", strerror(errno));
> Yes - I did that. That part is fine.
> Thanks
> Warmest regards
