UDP error
    Angelo Fraietta
    afraiett at bigpond.net.au
    Fri Jul  9 02:30:59 UTC 2004
Ian Caddy wrote:
> Hi,
> The if_stats and mbuf_stats can be called at anytime and will print out
> the statistics to your default console, I assume you have one of these.
> Depending on how quickly you get this no buffers error, I would setup a
> test task (or use one that is already in a loop) that called these
> functions every x seconds (minutes, depending on time between errors).
> You could then see how your buffers were progressing.
Of course it won't fail now, but thanks.
I found that I had to place extern "C" around the #incude rtems_bsdnet.h
to make it compile. No big deal though.
> Once you get the no buffers error, it is too late to see as you know you
> have none left.
I detected that the sendto failed and stored the value and sent later.
Thanks
Angelo Fraietta
PO Box 859
Hamilton NSW 2303
Home Page
http://www.users.bigpond.com/angelo_f/
There are those who seek knowledge for the sake of knowledge - that is
CURIOSITY
There are those who seek knowledge to be known by others - that is VANITY
There are those who seek knowledge in order to serve - that is LOVE
     Bernard of Clairvaux (1090 - 1153)
