Memory usage
Thu Jul 22 00:45:04 UTC 2004
Etienne Fortin wrote:
> 6) A filesystem for an external Flash memory.
What file system ? These tend to use memory.
> Is it enough???? It HAS to be enough!!!
Which is it ?
> If not, where is the biggest memory overhead in what I want?
Why not get an eval board with plenty of RAM and see what happens ? It
is much easier to get help if we are given some data to work with.
You use nm with the --size-sort option to see what uses the most code or
data. The heap will require you to run the code.
  Chris Johns
