Debugging with RTEMS
Anthony Tonizzo
atonizzo at lycos.com
Thu Jul 22 14:25:06 UTC 2004
Hi:
I am fairly new to RTEMS, and I have been struggling with
debug issues of late.
I am developing on two different BSPs: a "pc686" and a PowerPC
based "mbx860_002" and both of them boot with a loader program
(RedBoot as it happens). RedBoot has built-in GDB stubs for both
Ethernet and serial port, and so I should be able to point the
ddd debugger to it and debug with the known, time tested commands:
target remote /dev/ttyS0
load
break somewhere
continue
I have compiled the hello_world_c for both platforms (with
the -g switch) and started ddd using the powerpc-rtems-gdb and
what I see is that after the "continue" command everything freezes
and my breakpoint (right at the beginning of the Init() function)
never seems to be hit. I have to kill ddd and hard reset the target.
So my question is how can I debug applications in RTEMS using
gdb, insight, ddd etc. with the help of the gdb stubs that are
already in place in my target? Is there something I need to do?
Am I missing a step?
Thanks
Tony
Find what you are looking for with the Lycos Yellow Pages
http://r.lycos.com/r/yp_emailfooter/http://yellowpages.lycos.com/default.asp?SRC=lycos10
