Executive shutdown
Stevens Brian BPSTEVENS at qinetiq.com
Fri Jul 2 08:47:38 UTC 2004
I have added a counter and it indicates that the task receives approx 280
signals before failing.
-----Original Message-----
From: Angelo Fraietta [mailto:afraiett at bigpond.net.au]
Sent: 02 July 2004 09:39
To: Stevens Brian
Cc: 'rtems-users at rtems.com'
Subject: Re: Executive shutdown
Stevens Brian wrote:
>RTEMS version 4.6
>Target PC386
>I have written a device driver to use the rtc to generate timer interrupts
>independent of the clock used to drive rtems. I have set  the additional
>timer to produce interupts at 122micro second intervals, these are then
>counted and when the required time interval has elapsed a POSIX signal is
>sent to a thread.
>If I set the signal to be sent every  2 miliseconds the system eventually
>crashes with an executive shutdown. However, if set to 20ms it works fine.
After how long does it crash? Do you get a message saying that it shust down
Angelo Fraietta
PO Box 859
Hamilton NSW 2303
Home Page
http://www.users.bigpond.com/angelo_f/
There are those who seek knowledge for the sake of knowledge - that is
CURIOSITY
There are those who seek knowledge to be known by others - that is VANITY
There are those who seek knowledge in order to serve - that is LOVE
    Bernard of Clairvaux (1090 - 1153)
The Information contained in this E-Mail and any subsequent correspondence
is private and is intended solely for the intended recipient(s).
For those other than the recipient any disclosure, copying, distribution,
or any action taken or omitted to be taken in reliance on such information
is prohibited and may be unlawful.
Emails and other electronic communication with QinetiQ may be monitored.
Calls to QinetiQ may be recorded for quality control,
regulatory and monitoring purposes.
