Problem with ATA driver on pc386
Angelo Fraietta
afraiett at bigpond.net.au
Mon Jul 5 00:45:59 UTC 2004
Greeting all
Angelo Fraietta wrote:
> Greetings Eugene
>>>> Unfortunately system hungs up when I enabling ATA driver.
>> Yes I did, however I think my problem was not similar to yours. I
>> found the cause in multiple file systems on my hdd and GRUB installed
>> in MBR.
> This is probably not as dissimilar as you suspect. This made me do
> some more tests and have identified where the problem may lie.
> What I did not mention is that my PC104 system does not have any
> drives plugged into the primary IDE -- the compact flash is the
> secondary master.
> If on my DIMMPC, I disable the onboard IDE (i.e. no hard drive), the
> system hangs at the same place - ATA_DRIVER_TABLE_ENTRY
> What I suspect is happening is that the absence of a drive in the
> Primary IDE cause the initialisation to hang. I don't have a drive
> that I can plug into the primary IDE of the PC104 to prove this. I'll
> try and get my hands on one to substantiate my theory.
I can now confirm that this is the case. I plugged the compact flash
into the Primary IDE port as a MaSTER (through a converter I borrowed)
and the the system works. I then changed it to a Primary Slave and it
hung. There must therefore be some code in the ata_initialize (in ata.c)
that is hanging if no Primary Master exists.
I need the disk to be the Secondary Master with nothing on the Primary
port. Am I supposed to raise a PR with this?
Angelo Fraietta
PO Box 859
Hamilton NSW 2303
Home Page
http://www.users.bigpond.com/angelo_f/
There are those who seek knowledge for the sake of knowledge - that is CURIOSITY
There are those who seek knowledge to be known by others - that is VANITY
There are those who seek knowledge in order to serve - that is LOVE
Bernard of Clairvaux (1090 - 1153)
