Rebuilding RTEMS problem.
Steve Holle sholle at link-comm.com
Fri Jun 4 14:14:08 UTC 2004
At 02:05 AM 6/4/2004, EL KOLLI Yacine wrote:
>Steve Holle wrote:
>>I'm trying to rebuild RTEMS and am getting the following errors :
>>checking for RTEMS_CPU_MODEL... mcf5272
>>checking for RTEMS_BSP_FAMILY... (cached) tcb2
>>checking for CPU_CFLAGS... (cached) -m5200
>>checking for CFLAGS_OPTIMIZE_V... (cached) -O
>>checking for CFLAGS_DEBUG_V... (cached)
>>checking for CFLAGS_PROFILE_V... (cached)
>>checking for style of include used by make... GNU
>>checking for m68k-rtems-gcc... no
>>configure: error: no acceptable cc found in $PATH
>>make[2]: *** [tcb2] Error 1
>>make[2]: Leaving directory `/tcb2/rtems/build/m68k-rtems/c'
>>make[1]: *** [all-recursive] Error 1
>>make[1]: Leaving directory `/tcb2/rtems/build/m68k-rtems/c'
>>make: *** [all-recursive] Error 1
>>I have a copy of cc.exe in my cygwin/bin directory and have re-installed
>>cygwin with no help.  My mounts are as follows :
>>$ mount
>>C:\cygwin\usr\X11R6\lib\X11\fonts on /usr/X11R6/lib/X11/fonts type system
>>(binmode)
>>C:\cygwin\bin on /usr/bin type system (binmode)
>>C:\cygwin\lib on /usr/lib type system (binmode)
>>C:\cygwin on / type system (binmode)
>>c: on /cygdrive/c type user (binmode,noumount)
>>d: on /cygdrive/d type user (binmode,noumount)
>>e: on /cygdrive/e type user (binmode,noumount)
>>Any ideas?
>>Steve Holle
>>Link Communications, Inc.
>>1035 Cerise Rd.
>>Billings, MT  59101
>This can happen if the environment variable CC is defined, wath ever is
>its definition. If it is defined try with CC left undefined.
Where would this get defined at?  We use configure and make all to
build?  As you can probably tell, I am clueless about this
environment.  Any help would be greatly appreciated.
>Yacine.
>EL KOLLI Yacine         | yacine.elkolli at crf.canon.fr
>Canon C.R.F.            | Phone: +33.(0)2.99.87.68.79
>http://www.crf.canon.fr | FAX: +33.(0)2.99.84.11.30
Steve Holle
1035 Cerise Rd.
Billings, MT  59101
