Rebuilding RTEMS problem.
EL KOLLI Yacine yacine.elkolli at crf.canon.fr
Fri Jun 4 14:31:43 UTC 2004
Steve Holle wrote:
> At 02:05 AM 6/4/2004, EL KOLLI Yacine wrote:
>> Steve Holle wrote:
>>> I'm trying to rebuild RTEMS and am getting the following errors :
>>> checking for RTEMS_CPU_MODEL... mcf5272
>>> checking for RTEMS_BSP_FAMILY... (cached) tcb2
>>> checking for CPU_CFLAGS... (cached) -m5200
>>> checking for CFLAGS_OPTIMIZE_V... (cached) -O
>>> checking for CFLAGS_DEBUG_V... (cached)
>>> checking for CFLAGS_PROFILE_V... (cached)
>>> checking for style of include used by make... GNU
>>> checking for m68k-rtems-gcc... no
>>> configure: error: no acceptable cc found in $PATH
>>> make[2]: *** [tcb2] Error 1
>>> make[2]: Leaving directory `/tcb2/rtems/build/m68k-rtems/c'
>>> make[1]: *** [all-recursive] Error 1
>>> make[1]: Leaving directory `/tcb2/rtems/build/m68k-rtems/c'
>>> make: *** [all-recursive] Error 1
>>> I have a copy of cc.exe in my cygwin/bin directory and have
>>> re-installed cygwin with no help.  My mounts are as follows :
>>> $ mount
>>> C:\cygwin\usr\X11R6\lib\X11\fonts on /usr/X11R6/lib/X11/fonts type
>>> system (binmode)
>>> C:\cygwin\bin on /usr/bin type system (binmode)
>>> C:\cygwin\lib on /usr/lib type system (binmode)
>>> C:\cygwin on / type system (binmode)
>>> c: on /cygdrive/c type user (binmode,noumount)
>>> d: on /cygdrive/d type user (binmode,noumount)
>>> e: on /cygdrive/e type user (binmode,noumount)
>>> Any ideas?
>>> Steve Holle
>>> Link Communications, Inc.
>>> 1035 Cerise Rd.
>>> Billings, MT  59101
>>> sholle at link-comm.com
>> This can happen if the environment variable CC is defined, wath ever
>> is its definition. If it is defined try with CC left undefined.
> Where would this get defined at?  We use configure and make all to
> build?  As you can probably tell, I am clueless about this environment.
> Any help would be greatly appreciated.
I'am not familiar with windows/cygwin, but I guess that this can be
found in the control panel/ syetem/ advanced/ environment variables
If you type 'set' in a dos window then you can check if you have CC
defined. It it is defined try 'unset CC', then rebuild in that same window
Again I'am not familiar with this environment...
>> Yacine.
>> EL KOLLI Yacine         | yacine.elkolli at crf.canon.fr
>> Canon C.R.F.            | Phone: +33.(0)2.99.87.68.79
>> http://www.crf.canon.fr | FAX: +33.(0)2.99.84.11.30
> Steve Holle
> 1035 Cerise Rd.
> Billings, MT  59101
