Rebuilding RTEMS problem.
Joel Sherrill <joel@OARcorp.com> joel.sherrill at OARcorp.com
Sat Jun 5 14:46:30 UTC 2004
Chris Caudle wrote:
>>I'am not familiar with windows/cygwin, but I guess that this can be
>>found in the control panel/ syetem/ advanced/ environment variables
> That just sets the Windows environment variables, Cygwin can import some of those environment variables, but some are set separately.
> I found this user's guide for Cygwin:
> http://cygwin.com/cygwin-ug-net/cygwin-ug-net.html
> Here is a specific section on setting environment variables:
> http://cygwin.com/cygwin-ug-net/setup-env.html
> Some variables may also be set in the files .profile or .bashrc, they need to be checked to make sure.
At a Cygwin prompt, you can do this:
env | grep VARIABLE
and find out if something like CC or LIB is set.
I recall that at one time Ralf posted a script which checked for
bad things in the environment.  Maybe it needs to be included
in the RTEMS source distribution so we can point people to it.
> -- Chris Caudle
