Rebuilding RTEMS problem.
Steve Holle
sholle at link-comm.com
Fri Jun 4 14:45:57 UTC 2004
At 08:31 AM 6/4/2004, EL KOLLI Yacine wrote:
>Steve Holle wrote:
>>At 02:05 AM 6/4/2004, EL KOLLI Yacine wrote:
>>>Steve Holle wrote:
>>>>I'm trying to rebuild RTEMS and am getting the following errors :
>>>>checking for RTEMS_CPU_MODEL... mcf5272
>>>>checking for RTEMS_BSP_FAMILY... (cached) tcb2
>>>>checking for CPU_CFLAGS... (cached) -m5200
>>>>checking for CFLAGS_OPTIMIZE_V... (cached) -O
>>>>checking for CFLAGS_DEBUG_V... (cached)
>>>>checking for CFLAGS_PROFILE_V... (cached)
>>>>checking for style of include used by make... GNU
>>>>checking for m68k-rtems-gcc... no
>>>>configure: error: no acceptable cc found in $PATH
>>>>make[2]: *** [tcb2] Error 1
>>>>make[2]: Leaving directory `/tcb2/rtems/build/m68k-rtems/c'
>>>>make[1]: *** [all-recursive] Error 1
>>>>make[1]: Leaving directory `/tcb2/rtems/build/m68k-rtems/c'
>>>>make: *** [all-recursive] Error 1
>>>>I have a copy of cc.exe in my cygwin/bin directory and have
>>>>re-installed cygwin with no help. My mounts are as follows :
>>>>$ mount
>>>>C:\cygwin\usr\X11R6\lib\X11\fonts on /usr/X11R6/lib/X11/fonts type
>>>>system (binmode)
>>>>C:\cygwin\bin on /usr/bin type system (binmode)
>>>>C:\cygwin\lib on /usr/lib type system (binmode)
>>>>C:\cygwin on / type system (binmode)
>>>>c: on /cygdrive/c type user (binmode,noumount)
>>>>d: on /cygdrive/d type user (binmode,noumount)
>>>>e: on /cygdrive/e type user (binmode,noumount)
>>>>Any ideas?
>>>>Steve Holle
>>>>Link Communications, Inc.
>>>>1035 Cerise Rd.
>>>>Billings, MT 59101
>>>This can happen if the environment variable CC is defined, wath ever is
>>>its definition. If it is defined try with CC left undefined.
>>Where would this get defined at? We use configure and make all to
>>build? As you can probably tell, I am clueless about this environment.
>>Any help would be greatly appreciated.
>I'am not familiar with windows/cygwin, but I guess that this can be found
>in the control panel/ syetem/ advanced/ environment variables
>If you type 'set' in a dos window then you can check if you have CC
>defined. It it is defined try 'unset CC', then rebuild in that same window
>Again I'am not familiar with this environment...
I rand "set" and didn't find any "cc" or "CC" defined.
>>>Yacine.
>>>EL KOLLI Yacine | yacine.elkolli at crf.canon.fr
>>>Canon C.R.F. | Phone: +33.(0)2.99.87.68.79
>>>http://www.crf.canon.fr | FAX: +33.(0)2.99.84.11.30
>>Steve Holle
>>1035 Cerise Rd.
>>Billings, MT 59101
Steve Holle
1035 Cerise Rd.
Billings, MT 59101
