2 little rtems asks, please...
Alex
kbyte at iol.pt
Fri Mar 5 09:33:44 UTC 2004
Hi,
I am begining with the rtems and I have 2 little questions/doubts:
1. Looking to the hello world sample, what is the aim of the final
configuration comments? Is this a remember? Is that importante?
* Simple test program -- simplified version of sample test hello.
#include <bsp.h>
rtems_task Init(rtems_task_argument ignored)
printf( "\n\n*** HELLO WORLD TEST ***\n" );
printf( "Hello World\n" );
printf( "*** END OF HELLO WORLD TEST ***\n" );
exit( 0 );
/* configuration information */
/*#define CONFIGURE_TEST_NEEDS_CONSOLE_DRIVER
#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
#define CONFIGURE_MAXIMUM_TASKS 1
#define CONFIGURE_INIT
#include <confdefs.h>*/
/* end of file */
2. Which is the best way to measure the time of an operation?
Suppose you want to measure the execution time of the clock_gettime() function.
I have the following two ways. Does one is better than the other?
REM: I didn't execute my RTEMS programs yet, because I have to
prepare the floppy disk first. But could you give some tips about
the way to measure functions execution time? Is these good ways to do that?
WAY 1:
void diff_timespec(
struct timespec *start,
struct timespec *stop,
struct timespec *result
int nsecs_per_sec = 1000000000;
result->tv_sec = stop->tv_sec - start->tv_sec;
if ( stop->tv_nsec < start->tv_nsec ) {
result->tv_nsec = nsecs_per_sec - start->tv_nsec + stop->tv_nsec;
result->tv_sec--;
} else
result->tv_nsec = stop->tv_nsec - start->tv_nsec;
int status;
struct timespec start;
struct timespec current;
struct timespec difference;
struct timespec resolution;
status = clock_gettime( CLOCK_REALTIME, &start );
assert( !status );
int nResp = clock_getres(CLOCK_REALTIME, &resolution);
status = clock_gettime( CLOCK_REALTIME, ¤t );
assert( !status );
diff_timespec( &start, ¤t, &difference );
WAY 2:
timer_create(...)
timer_gettime(...)
REM: It is very important for me that the technique be POSIX compliant.
Any advices?
Thanks a lot.
Alex
___________________________________________________________________________________________
IOL Flash. A net normal em versao acelerada.
Precisa de uma caixa de correio maior? Com o IOL Flash pode ter uma caixa com 21MB de espaco.
Saiba mais sobre o IOL Flash: http://www.iol.pt/central_utilizador/iol_flash/
