Better timer resolution
    Stevens Brian
    BPSTEVENS at qinetiq.com
    Thu Mar 11 11:21:20 UTC 2004
I have been investigating the PC architecture and as far as I can establish
the only timer conencted to the interrupt controller is timer 0 on the the
8254 PIT.
This leaves the following alternatives:
*	Modify the default clock to use a better resolution
		This has the problems of increased processor load and needs
the clock routine to be modified to scale back to the original values.
*	Use the real time chip
		This can give a resoloution of 122 micro seconds, which is
good enough for my needs.
*	Use the Advanced Programmable Interrupt Controller
		This is available on later chips (pc686 ?) and seems to have
a timer function. I need to investigate this and may go this route if my
hardware will support it.  this of course means that it is not usable on all
PC systems.
Any comments, thoughts or assistance greatfully received.
Brian Stevens
QinetiQ
Cody Technology Park,
Ively Road,
Farnborough,
Hampshire
GU14 0LX .
UK
Telephone (01252) 393959
Fax          (01252) 395120
The Information contained in this E-Mail and any subsequent correspondence
is private and is intended solely for the intended recipient(s).
For those other than the recipient any disclosure, copying, distribution,
or any action taken or omitted to be taken in reliance on such information
is prohibited and may be unlawful.
Emails and other electronic communication with QinetiQ may be monitored.
Calls to QinetiQ may be recorded for quality control,
regulatory and monitoring purposes.
