sis: fp disabled??
Roman Schnider
schnider at aicas.com
Thu Mar 11 13:43:29 UTC 2004
Hi,
RTEMS 4.6 sparc, erc32 BSP
I try to run my application using the integrated simulator in
sparc-rtems-gdb. During execution, I get the following error:
Unexpected trap (0x04) at address 0x0200fd20
fp disabled
a backtrace in gdb shows this:
(gdb) bt
#0 syscall () at
../../../../../../../../rtems-4.6.0/c/src/lib/libcpu/sparc/syscall/syscall.S:54
#1 0x02030b24 in DEBUG_puts (string=0xe3 "") at
../../../../../../../../../rtems-4.6.0/c/src/lib/libbsp/sparc/erc32/console/debugputs.c:112
#2 0x02030f5c in bsp_spurious_handler (trap=37747504, isf=0x2057000)
at
../../../../../../../../../rtems-4.6.0/c/src/lib/libbsp/sparc/erc32/startup/spurious.c:140
#3 0x0203c8a8 in dont_fix_pil2 () at
../../../../../../../../rtems-4.6.0/cpukit/score/cpu/sparc/cpu_asm.S:598
[my application code]
I assume 'fp disabled' means no floating point support.
Did I miss any configure option when building the erc32 bsp?
Thanks for your help
Roman
Return-Path: <gregmatu at poczta.onet.pl>
Mailing-List: contact rtems-users-help at rtems.com; run by ezmlm
Delivered-To: mailing list rtems-users at rtems.com
Received: (qmail 7320 invoked from network); 11 Mar 2004 13:53:18 -0000
Received: from unknown (HELO smtp1k.poczta.onet.pl) (213.180.130.35)
by 0 with SMTP; 11 Mar 2004 13:53:18 -0000
Received: from pk2.test.onet.pl ([192.168.241.242]:4592 "EHLO pk2.test.onet.pl")
by kps1.test.onet.pl with ESMTP id <S162820AbUCKNwf>;
Thu, 11 Mar 2004 14:52:35 +0100
Content-Type: text/plain; charset=US-ASCII
Content-Disposition: inline
Content-Transfer-Encoding: 7BIT
MIME-Version: 1.0
Received: from 213.180.130.13 by 192.168.240.50 with HTTP; Thu,
11 Mar 2004 14:52:33 +0100 ,from 193.59.197.51 by 213.180.130.13 with HTTP
Date: Thu, 11 Mar 2004 14:52:35 +0100
To: rtems-users at rtems.com
Subject: Re: DOSFS problems solved
X-Priority: 0
X-Mailer: onet.poczta
Message-Id: <20040311135237Z162820-19549+48022 at kps1.test.onet.pl>
User Adriano Verardo wrote:
>Listing the file in the root dir of a disk, I see an empty file
>with the name equal to the disk label. Is it normal ?
I think it is normal.
Gregory Matus
