IP address woes
Angelo Fraietta
afraiett at bigpond.net.au
Tue May 18 20:49:48 UTC 2004
I am having trouble getting my RTEMS UDP to work properly with my RTEMS
project and my Mac.
The way it works is that I send a broadcast message to find my RTEMS
device by sending UDP to 192.168.0.255
My device always gets it and attempts to send a response to the exact IP
address that sent it. Often, it says that couldn't send socket - host is
down. Then I unplug and replug my mac and it can then send the response,
and my Mac receives it, and correctly determines the exact IP address of
my device. Then, if I try to send to the exact IP address, the Mac says
that the host is down. If I try to ping from the mac, I get a host is
down message.
If I go to a Windows machine connected on the network, I can ping both
the Mac and the RTEMS. In fact, I don't have any problems at all using
Windows.
I changed the chips on my device, and the error stayed with the chip -
i.e. the Mac worked with one and not the other. Then all of a sudden, it
swapped about the one that did not work worked, and vice versa. I know I
did not make a mistake on this part because I gave the response a unique
name that was configured in the the device as a text file.
Any idea's of what to look for?
Angelo Fraietta
PO Box 859
Hamilton NSW 2303
Home Page
http://www.users.bigpond.com/angelo_f/
There are those who seek knowledge for the sake of knowledge - that is CURIOSITY
There are those who seek knowledge to be known by others - that is VANITY
There are those who seek knowledge in order to serve - that is LOVE
Bernard of Clairvaux (1090 - 1153)
