Building the first application
Jack Cawkwell J.Cawkwell at open.ac.uk
Mon May 10 21:34:53 UTC 2004
Hi Etienne,
Although the answer is probably in the manuals, I did
not find it particularly easy to get a build to work,
and wrote the following script last time I did it,
last year?
If it helps, this is a script for building on an i386
linux box, which might help if you update it for the
current version, you need to comment out parts so
you run the rpm as root and the build as a mortal,and
alter paths to suit.
Jack.
# remove existing rpms
rpm -q -a | grep rtems |
while read PACK
do
  rpm -e --nodeps $PACK
done
# install rpm's as root
cd /home/src/rtems-cd/ftp.oarcorp.com/pub/rtems/cd-working
# base
rpm -i
./tools/gcc3.2.1newlib1.11.0-2/linux_x86/RPMS/rtems-base-gcc-gcc3.2.1newlib1.11.0-2.i686.rpm
rpm -i
./tools/binutils-2.13.2.1-1/linux_x86/RPMS/rtems-base-binutils-2.13.2.1-2.i686.rpm
rpm -i
./tools/autoconf-2.57-1/linux_x86/RPMS/autoconf-rtems-2.57-1.noarch.rpm
rpm -i
./tools/automake-1.7.2-1/linux_x86/RPMS/automake-rtems-1.7.2-1.noarch.rpm
rpm -i
./tools/gcc3.2.1newlib1.11.0-2/linux_x86/RPMS/rtems-base-gnat-gcc3.2.1newlib1.11.0-2.i686.rpm
# i386 specific
rpm -i
./tools/binutils-2.13.2.1-1/linux_x86/RPMS/i386-rtems-binutils-2.13.2.1-2.i686.rpm
rpm -i
./tools/gcc3.2.1newlib1.11.0-2/linux_x86/RPMS/i386-rtems-gcc-gcc3.2.1newlib1.11.0-2.i686.rpm
rpm -i
./tools/gcc3.2.1newlib1.11.0-2/linux_x86/RPMS/i386-rtems-c++-gcc3.2.1newlib1.11.0-2.i686.rpm
rpm -i
./tools/gcc3.2.1newlib1.11.0-2/linux_x86/RPMS/i386-rtems-gnat-gcc3.2.1newlib1.11.0-2.i686.rpm
cd /home/src/rtems-cd ; mkdir build_i386 ; cd build_i386
PATH=$PATH:/opt/rtems/bin
export RTEMS_MAKEFILE_PATH=/usr/local/pc386
# export RTEMS_MAKEFILE_PATH=/opt/rtems/i386-rtems/pc686
../rtems-4.6.0pre1/configure \
  --enable-cxx \
  --enable-tests \
  --build=i386 \
  --enable-rtemsbps=pc686 \
  --prefix=/opt/rtems \
  --program-prefix=i386-rtems- \
  --target=i386-rtems
make RTEMS_BSP=pc686
Etienne Fortin <etienne.fortin at sensio.tv> writes:
>Hi everyone,
>I have a some difficulties building the samples applications, and I
>suspect a very stupid newbie kind of error.
