Position independent m68k code + __builtin_memcpy
Joel Sherrill
joel.sherrill at OARcorp.com
Wed May 19 17:28:30 UTC 2004
geneSmith wrote:
> Tell me to go away since this is probably really a gcc question.
> When I use an old version of m68k-rtems-gcc (2.95.3) and I have a memcpy
> call in my code it inlines it automatically (per objdump). When I run
> the same code through the new m68k-rtems-gcc (3.2.3) I never get an
> inline but a call to the library function (even when I change it to
> __builtin_memcpy() and use option -fbuiltin as mentioned in the gcc
> 3.2.3 manual.
RTEMS sets TARGET_MEM_FUNCTIONS in gcc/config/rtems.h. Most of the
targets did this already so it became common. RTEMS has an optimized
m68k memcpy which we prefer to use. I don't know when precisely it
changed but gcc's cvs on that file and gcc/config/m68k/rtems.h should
be a clue.
> All I can find is that it won't inline memcpy if the length is a
> variable. In my case it is a constant.
I assume this is related.
> Anybody know what is going on here?
> Tks,
> -gene
