[Again] Help: RTEMS Threads, Preemptation and Time slicing...
Alex
kbyte at iol.pt
Mon Nov 1 10:34:06 UTC 2004
Mr joel,
I saw the online docs before I post my message and I realised that preemptation could be handled through posix api, so
my program is targeted to posix but as I cant switch the preemptation flag with posix I mixed posix and rtems std api and I wrote the following:
rtems_task_mode(RTEMS_PREEMPT|RTEMS_TIMESLICE, RTEMS_PREEMPT_MASK|RTEMS_TIMESLICE_MASK,&old_mode)
in the thread source code and in the main thread source code.
As I know, the instruction turns on preemptation and time slice, right?
We can mix posix and rtems std api in the same program, right?
Am I confusing any concepts about this?
ok, but I will study the rtems scheduler source code to see what is happening,
Thanks to all of you.
Alex
http://www.rtems.org/onlinedocs/releases/rtemsdocs-
> 4.6.2/share/rtems/html/c_user/c_user00050.html
> And POSIX does not give this level of control over the threading
> attributes. You have SCHED_FIFO, SCHED_RR, etc. See
> 4.6.2/share/rtems/html/posix_users/posix_users00278.html
----- Mensagem Original -----
De: Joel Sherrill joelOARcorpcom <joel.sherrill at OARcorp.com>
Data: Sabado, 30 de Outubro de 2004, 15:05
Assunto: Re: [Again] Help: RTEMS Threads, Preemptation and Time slicing...
> Thomas Doerfler wrote:
> > Alex,
> > first of all: would you mind switching the "urgent" flag off,
> > when you send mail to the rtems mailing list? I am sure the
> > issue is important and maybe also urgent for you, but on a
> > mailing list it looks like "read my message first, the others
> > are not so important" and I am sure this is not what you really
> > want to look like :-)
> > I am not so familiar with the POSIX API, but I would guess that
> > disabling preemption will also disable timeslicing. And, if you
> > did not modify your source code after your first mail, your
> > system clock driver is still not active, therefore the system
> > has no time information and no ability for timeslicing.
> Preemption MUST be enabled to have timeslicing. See
> --joel
> > wkr,
> > thomas.
> >>Thank you to all of you, but let me explain better what I want:
> >>I know that my sample code is "dummy", but no problem, what I
> want is to make some threading tests to rtems for i386 arch, so,
> sometimes, the "dummy" projects are the best to test the real
> capabilities of the systems, right?, because, if people always
> write fine and objective programs we never test the system in
> other (dumies, may be :-) ) conditions.
> >>So, what I want it to have one thread running (like the "dummy"
> for cicle I wrote) and I wat to see the other thread, executing
> the same dummy code, to enter in the cpu DUE to time slicing. I
> dont want to use bloking instructions like sleeps, "wait for
> single object" and somethings like these.
> >>I already tested the rtems threads with this kind of blocking
> instructions and the systems work fine, but now I want to see
> thread switching between threads with same priority, due to time
> slicing.>>
> >>In my sample program, I think I turned off preemptation and I
> turned on the time slicing right? But the system doesnt switch
> between the threads...
> >>Is this a rtems scheduler bug?
> >>Is this a bug in my code? (I thing it is, but where?)
> >> I am a beginner in rtems and I need help from you...
> >>Thanks once again...
> >>Alex
> >>Data: Quinta-Feira, 28 de Outubro de 2004, 12:24
> >>Assunto: Re: Help: RTEMS Threads, Preemptation and Time slicing...
> >>>Ian Caddy wrote:
> >>>>Hi Alex,
> >>>>If your threads are the same priority, pre-emption will not
> >>>cause one of
> >>>>them to stop, as it will only pre-empt for HIGHER priority
> threads.>>>>
> >>>>In this case, you will need to configure these threads for
> round-
> >>>robbin
> >>>>(or timeslicing) to achieve what you are asking.
> >>>>In saying that though, your system design should never, in
> >>>practise,
> >>>>consist of tasks that are continuously running as no other
> task
> >>>of a
> >>>>lower priority level will ever get to run in this sort of
> >>>system. A
> >>>>normal system design will have tasks waiting on things from
> >>>other tasks,
> >>>>or if not, sleeps that allow the task to yield to lower
> priority
> >>>tasks.
> >>>I find that often people have threads that either execute much
> quicker>>>then the timeslicing quantum or have no scheduling
> points so
> >>>unless
> >>>timeslicing is enabled, there is no switching.
> >>>Unless you configure the system differently, the timeslice
> quantum
> >>>is 10
> >>>milliseconds which is a LOT of CPU cycles on most modern CPUs.
> >>>Tasking Design Rule: Find ways for your tasks to naturally
> block
> >>>so they
> >>>spent most of their life blocked.
> >>>--joel
> >>>>I hope this helps.
> >>>>regards,
> >>>>Ian Caddy
> >>>>Alex wrote:
> >>>>>Hi all,
> >>>>>I am making little rtems programs involving threads and the
> >>>POSIX API.
> >>>>>I want to create a program that launchs 2 threads via posix
> >>>calls.
> >>>>>Then I want to split the processor attent to both threads, i
> >>>mean,
> >>>>>both threads must execute in "parallel" and not to
> >>>>>wait one from another...
> >>>>>The RTEMS manual says the scheduler look to the different
> taks
> >>>in this
> >>>>>order:
> >>>>>Priority, preemptation (when activated) and then time slicing
> >>>(when
> >>>>>activated), right?
> >>>>>So, in the rtems program I launch the 2 extra threads with
> >>>equal
> >>>>>priority, priority 1! For each thread, including the main
> >>>thread I
> >>>>>turn on the preemptation and time slicing, but the
> >>>>>second extra thread only starts execution when the first
> extra
> >>>thread
> >>>>>finishs its execution.
> >>>>>I cant understand why... :-(
> >>>>>Note: If I use a, for example, the sleep() instruction in the
> >>>body of
> >>>>>the thread, the processor
> >>>>>is switch to the other extra thread in a good way, but if i
> >>>dont use
> >>>>>functions that transfer the
> >>>>>execution to other threads, the processor is never switched
> to
> >>>other
> >>>>>threads...
> >>>>>Can you help me? How to execute the 2 extra threads at the
> same
> >>>time
> >>>>>while the main thread is waiting for the 2 extra threads?
> >>>>>by the way, is there any way to turn on preemptation and time
> >>>slicing
> >>>>>using only posix api?
> >>>Joel Sherrill, Ph.D. Director of Research & Development
> >>>joel at OARcorp.com On-Line Applications Research
> >>>Ask me about RTEMS: a free RTOS Huntsville AL 35805
> >>> Support Available (256) 722-9985
> >>________________________________________________________________________________
> >>A protecção do e-mail contra vírus é cada vez mais necessária!
> >>Proteja a sua Caixa de Correio:
> http://www.iol.pt/correio/rodape.php?dst=0409301>>
> > IMD Ingenieurbuero fuer Microcomputertechnik
> > Thomas Doerfler Herbststrasse 8
> > D-82178 Puchheim Germany
> > email: Thomas.Doerfler at imd-systems.de
> > PGP public key available at: http://www.imd-
> > systems.de/pgp_keys.htm
Um acesso à internet com anti-vírus, bloqueador de janelas e caixa de correio com 21 MB?
IOL. Tem tudo para ser mais simples.
Saiba como instalar: http://www.iol.pt/correio/rodape.php?dst=0409231
