[Again] Help: RTEMS Threads, Preemptation and Time slicing...
Ian Caddy
ianc at microsol.iinet.net.au
Tue Nov 2 02:06:25 UTC 2004
Hi Alex,
Alex wrote:
> Mr joel,
> I saw the online docs before I post my message and I realised that preemptation could be handled through posix api, so
> my program is targeted to posix but as I cant switch the preemptation flag with posix I mixed posix and rtems std api and I wrote the following:
> rtems_task_mode(RTEMS_PREEMPT|RTEMS_TIMESLICE, RTEMS_PREEMPT_MASK|RTEMS_TIMESLICE_MASK,&old_mode)
> in the thread source code and in the main thread source code.
> As I know, the instruction turns on preemptation and time slice, right?
That is correct.
> We can mix posix and rtems std api in the same program, right?
That is also correct, the only problem would be that you couldn't
perform a straight port of your code over to another posix system as it
contains RTEMS calls in it.
> Am I confusing any concepts about this?
No, I think you are getting there.
> ok, but I will study the rtems scheduler source code to see what is happening,
From an earlier email, Thomas indicated that it didn't look like you
had a clock running, and without a clock you will not be able to get
functioning timeslicing as the clock is required for this.
regards,
Ian Caddy
> http://www.rtems.org/onlinedocs/releases/rtemsdocs-
>>4.6.2/share/rtems/html/c_user/c_user00050.html
>>And POSIX does not give this level of control over the threading
>>attributes. You have SCHED_FIFO, SCHED_RR, etc. See
>>4.6.2/share/rtems/html/posix_users/posix_users00278.html
> ----- Mensagem Original -----
> De: Joel Sherrill joelOARcorpcom <joel.sherrill at OARcorp.com>
> Data: Sabado, 30 de Outubro de 2004, 15:05
> Assunto: Re: [Again] Help: RTEMS Threads, Preemptation and Time slicing...
>>Thomas Doerfler wrote:
>>>Alex,
>>>first of all: would you mind switching the "urgent" flag off,
>>>when you send mail to the rtems mailing list? I am sure the
>>>issue is important and maybe also urgent for you, but on a
>>>mailing list it looks like "read my message first, the others
>>>are not so important" and I am sure this is not what you really
>>>want to look like :-)
>>>I am not so familiar with the POSIX API, but I would guess that
>>>disabling preemption will also disable timeslicing. And, if you
>>>did not modify your source code after your first mail, your
>>>system clock driver is still not active, therefore the system
>>>has no time information and no ability for timeslicing.
>>Preemption MUST be enabled to have timeslicing. See
>>--joel
>>>wkr,
>>>thomas.
>>>>Thank you to all of you, but let me explain better what I want:
>>>>I know that my sample code is "dummy", but no problem, what I
>>want is to make some threading tests to rtems for i386 arch, so,
>>sometimes, the "dummy" projects are the best to test the real
>>capabilities of the systems, right?, because, if people always
>>write fine and objective programs we never test the system in
>>other (dumies, may be :-) ) conditions.
>>>>So, what I want it to have one thread running (like the "dummy"
>>for cicle I wrote) and I wat to see the other thread, executing
>>the same dummy code, to enter in the cpu DUE to time slicing. I
>>dont want to use bloking instructions like sleeps, "wait for
>>single object" and somethings like these.
>>>>I already tested the rtems threads with this kind of blocking
>>instructions and the systems work fine, but now I want to see
>>thread switching between threads with same priority, due to time
>>slicing.>>
>>>>In my sample program, I think I turned off preemptation and I
>>turned on the time slicing right? But the system doesnt switch
>>between the threads...
>>>>Is this a rtems scheduler bug?
>>>>Is this a bug in my code? (I thing it is, but where?)
>>>>I am a beginner in rtems and I need help from you...
>>>>Thanks once again...
>>>>Alex
>>>>Data: Quinta-Feira, 28 de Outubro de 2004, 12:24
>>>>Assunto: Re: Help: RTEMS Threads, Preemptation and Time slicing...
>>>>>Ian Caddy wrote:
>>>>>>Hi Alex,
>>>>>>If your threads are the same priority, pre-emption will not
>>>>>cause one of
>>>>>>them to stop, as it will only pre-empt for HIGHER priority
>>threads.>>>>
>>>>>>In this case, you will need to configure these threads for
>>round-
>>>>>robbin
>>>>>>(or timeslicing) to achieve what you are asking.
>>>>>>In saying that though, your system design should never, in
>>>>>practise,
>>>>>>consist of tasks that are continuously running as no other
>>task
>>>>>of a
>>>>>>lower priority level will ever get to run in this sort of
>>>>>system. A
>>>>>>normal system design will have tasks waiting on things from
>>>>>other tasks,
>>>>>>or if not, sleeps that allow the task to yield to lower
>>priority
>>>>>tasks.
>>>>>I find that often people have threads that either execute much
>>quicker>>>then the timeslicing quantum or have no scheduling
>>points so
>>>>>unless
>>>>>timeslicing is enabled, there is no switching.
>>>>>Unless you configure the system differently, the timeslice
>>quantum
>>>>>is 10
>>>>>milliseconds which is a LOT of CPU cycles on most modern CPUs.
>>>>>Tasking Design Rule: Find ways for your tasks to naturally
>>block
>>>>>so they
>>>>>spent most of their life blocked.
>>>>>--joel
>>>>>>I hope this helps.
>>>>>>regards,
>>>>>>Ian Caddy
>>>>>>Alex wrote:
>>>>>>>Hi all,
>>>>>>>I am making little rtems programs involving threads and the
>>>>>POSIX API.
>>>>>>>I want to create a program that launchs 2 threads via posix
>>>>>calls.
>>>>>>>Then I want to split the processor attent to both threads, i
>>>>>mean,
>>>>>>>both threads must execute in "parallel" and not to
>>>>>>>wait one from another...
>>>>>>>The RTEMS manual says the scheduler look to the different
>>taks
>>>>>in this
>>>>>>>order:
>>>>>>>Priority, preemptation (when activated) and then time slicing
>>>>>(when
>>>>>>>activated), right?
>>>>>>>So, in the rtems program I launch the 2 extra threads with
>>>>>equal
>>>>>>>priority, priority 1! For each thread, including the main
>>>>>thread I
>>>>>>>turn on the preemptation and time slicing, but the
>>>>>>>second extra thread only starts execution when the first
>>extra
>>>>>thread
>>>>>>>finishs its execution.
>>>>>>>I cant understand why... :-(
>>>>>>>Note: If I use a, for example, the sleep() instruction in the
>>>>>body of
>>>>>>>the thread, the processor
>>>>>>>is switch to the other extra thread in a good way, but if i
>>>>>dont use
>>>>>>>functions that transfer the
>>>>>>>execution to other threads, the processor is never switched
>>to
>>>>>other
>>>>>>>threads...
>>>>>>>Can you help me? How to execute the 2 extra threads at the
>>same
>>>>>time
>>>>>>>while the main thread is waiting for the 2 extra threads?
>>>>>>>by the way, is there any way to turn on preemptation and time
>>>>>slicing
>>>>>>>using only posix api?
>>>>>Joel Sherrill, Ph.D. Director of Research & Development
>>>>>joel at OARcorp.com On-Line Applications Research
>>>>>Ask me about RTEMS: a free RTOS Huntsville AL 35805
>>>>> Support Available (256) 722-9985
>>>>________________________________________________________________________________
>>>>A protecção do e-mail contra vírus é cada vez mais necessária!
>>>>Proteja a sua Caixa de Correio:
>>http://www.iol.pt/correio/rodape.php?dst=0409301>>
>>>IMD Ingenieurbuero fuer Microcomputertechnik
>>>Thomas Doerfler Herbststrasse 8
>>>D-82178 Puchheim Germany
>>>email: Thomas.Doerfler at imd-systems.de
>>>PGP public key available at: http://www.imd-
>>>systems.de/pgp_keys.htm
> Um acesso à internet com anti-vírus, bloqueador de janelas e caixa de correio com 21 MB?
> IOL. Tem tudo para ser mais simples.
> Saiba como instalar: http://www.iol.pt/correio/rodape.php?dst=0409231
