Network Question..
Wilfried Busalski
w.busalski at lancier-monitoring.de
Tue Nov 2 09:33:09 UTC 2004
Hi community..
I have a system with tcp/ip ethernet-interface and tcp/ip modem-interface.
If the system get a phonecall from outside it install's a tcp/ip connect.
Same when the system lost connection via ethernet, it call's a connection
via modem. that all is working good, but the problem if got is, that the
modem can't install a correct default-gateway while the ethernet-connect has
installed the default gateway before.
My question: how can I install a second default-gateway to the
modem-interface?
best regards
W. Busalski
Type: application/ms-tnef
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20041102/9c578386/attachment.bin>
