could task dispatching be enabled in libc_delete_hook() ?
Till Straumann strauman at slac.stanford.edu
Thu Nov 11 15:09:11 UTC 2004
Joel.
I'm playing with some code that intends to plug the recently reported
memory leaks caused by libc cleanup code at task deletion.
I came across a problem (PR#716) which could be solved easily
if task dispatching could temporarily be enabled in the libc_delete_hook().
Could you please give an analysis whether this would be safe?
Thanks
-- Till
PS: I believe 716 exists independent of my modifications, it just
is less obvious (since it would only appear if a task with a unflushed
stream other than stdout/stderr is deleted).
