could task dispatching be enabled in libc_delete_hook() ?
Chris Johns
chrisj at rtems.org
Thu Nov 11 21:58:34 UTC 2004
Till Straumann wrote:
> I came across a problem (PR#716) which could be solved easily
> if task dispatching could temporarily be enabled in the libc_delete_hook().
> Could you please give an analysis whether this would be safe?
I would say no. The delete call is provided with the current thread and
if you enable dispatching will current be current when you get back
control and disable dispatching. Sure you could look at
_Thread_Executing but this is a bit of a hack.
Another issue is the extensions list order is not controlled so an API
may have deleted its user or API extension and another thread may try to
do something with the thread via an API.
> PS: I believe 716 exists independent of my modifications, it just
> is less obvious (since it would only appear if a task with a unflushed
> stream other than stdout/stderr is deleted).
I see the need to make sure all memory allocated to a task is released
when the task is closed, and maybe flushing buffers (but no convinced)
but closing open files seems to be mixing a process model with a thread
model.
Chris Johns
