Task Information from a Debugger
Leon Pollak leonp at plris.com
Tue Nov 16 12:39:17 UTC 2004
On Tuesday 16 November 2004 14:32, Mark VanderVoord wrote:
> I have an application that eventually runs into a problem, where only
> one task seems to be running.  Strangely enough, it's the lowest
> priority task in the system.  I'd like to be able to look at what the
> priority of all the tasks are, and what the status of the other tasks
> are when this happens.
> I have a debugger which I can use to check for this information (an
> Abatron BDI2000), but I don't know where to look.  Are the status and
> priority stored in a table somewhere?  Can anyone point me to the file
> or structure that I am interested in?
Attached is the file I received from Joel (thanks a lot to him) which does
what you want.
just call the dump_tasks macro.
Regards
Leon M.Pollak
leonp at plris dot com
# $Id: .gdb4rtems,v 1.1 2003/12/08 17:03:49 leonp Exp $
# GDB macros for analyzing RTEMS threads
# bt_task
# ABSTRACT
#    Print backtrace of an RTEMS task
# ARGUMENTS:
#    arg0 = pointer to the Thread_Control of the task.
define bt_task
    set $stkp = $arg0->Registers.gpr1
        set $stkp = *(void**)$stkp
        while $stkp != 0
            info line **((void**)$stkp+1)
        end
end
# dump1task
# ABSTRACT
#    Print information about an RTEMS task
# ARGUMENTS
#    arg0 = Task index in the corresponding _Information table.
#    arg1 = pointer to the Thread_Control of the task.
#    arg2 = 1 for verbose output, 0 otherwise
define dump1task
        set $d1t_num = $arg0
        set $pt = $arg1
        set $d1t_verbose = $arg2
        printf "%2d | ", $d1t_num
    set $id = $pt->Object.id
        set $name = (unsigned int)$pt->Object.name
        set $n0 = (char) ($name >> 24)
        if $n0 < ' ' || $n0 > 'z'
            set $n0=' '
        end
        printf "%c",$n0
        set $n1 = (char) (0xff & ($name >> 16))
        if $n1 < ' ' || $n1 > 'z'
            set $n1=' '
        end
        printf "%c",$n1
        set $n2 = (char) (0xff & ($name >> 8))
        if $n2 < ' ' || $n2 > 'z'
            set $n2=' '
        end
        printf "%c",$n2
        set $n3 = (char) (0xff & $name)
        if $n3 < ' ' || $n3 > 'z'
            set $n3=' '
        end
        printf "%c | ",$n3
        printf "%08x | ",$id
        set $state = $pt->current_state
        set $pri = $pt->current_priority
        printf "%3d | ",$pri
        set $ticks = $pt->ticks_executed
        printf "%8d | ", $ticks
        set $thread_pc = $pt->Registers.pc
        printf ""
        if $state == 0
                printf "READY"
        end
        if $state & 1
                printf "DORM "
        end
        if $state & 2
                printf "SUSP "
        end
        if $state & 4
                printf "TRANS "
        end
        if $state & 8
                printf "DELAY "
        end
        if $state & 0x10
                printf "Wtime "
        end
        if $state & 0x20
                printf "Wbuf "
        end
        if $state & 0x40
                printf "Wseg "
        end
        if $state & 0x80
                printf "Wmsg "
        end
        if $state & 0x100
                printf "Wevnt "
        end
        if $state & 0x200
                printf "Wsem "
        end
        if $state & 0x400
                printf "Wmutex "
        end
        if $state & 0x800
                printf "Wcvar "
        end
        if $state & 0x1000
                printf "Wjatx "
        end
        if $state & 0x2000
                printf "Wrpc "
        end
        if $state & 0x4000
                printf "Wrate "
        end
        if $state & 0x8000
                printf "Wsig "
        end
        if $state & 0x10000
                printf "Wisig "
        end
    printf "\n\
---+------+----------+-----+----------+------------------------------\n"
        if $d1t_verbose
           printf "\
BACKTRACE\n\
~~~~~~~~~\n"
           bt_task $pt
        end
end
# task_header
# ABSTRACT
#    Print the header of the task list table
define task_header
    printf "\
=====================================================================\n"
  printf "\
 # | Name |    ID    | Pri |  Ticks   | State\n"
    printf "\
end
# show_task_support
# ABSTRACT
#    Support routine for verbose listing of a single task
# ARGUMENTS
#    arg0 = _Information table.
#    arg1 = index.
define show_task_support
        task_header
    set $pt = (Thread_Control *)$arg0.local_table[$arg1]
    dump1task $arg1 $pt 1
end
# dump_tasks_support
# ABSTRACT
#    Support routine for verbose listing of all tasks of a given class
# ARGUMENTS
#    arg0 = _Information table for the class (internal, classic, POSIX etc.).
define dump_tasks_support
  task_header
  set $index = 1
  while $index <= $arg0.maximum
    set $pt = (Thread_Control *)$arg0.local_table[$index]
    if $pt != 0
                dump1task $index $pt 0
    end
    set $index = $index + 1
  end
end
# dump_internal_tasks
# ABSTRACT
#    Dump all internal tasks
define dump_internal_tasks
  dump_tasks_support  _Thread_Internal_information
end
# dump_tasks
# ABSTRACT
#    Dump all Classic tasks
define dump_tasks
  dump_tasks_support  _RTEMS_tasks_Information
end
# dump_pthreads
# ABSTRACT
#    Dump all POSIX threads
define dump_pthread
  dump_tasks_support  _POSIX_Threads_Information
end
# dump_all_tasks
# ABSTRACT
#    Dump all tasks of all classes (internal, POSIX and Classic)
define dump_all_tasks
  printf "Executing: 0x%x, Heir: 0x%x\n", _Thread_Executing->Object.id,\
    _Thread_Heir.Object.id
  printf "===============================================================================\n"
  printf "Internal Tasks\n"
  printf "Classic Tasks\n"
  printf "POSIX Tasks\n"
end
# show_internal_task
# ABSTRACT
#    Verbosely list a single internal task
# ARGUMENTS
#    arg0 = index in the _Information table
define show_internal_task
  show_task_support  _Thread_Internal_information $arg0
end
# show_task
# ABSTRACT
#    Verbosely list a single classic task
# ARGUMENTS
define show_task
  show_task_support  _RTEMS_tasks_Information $arg0
end
# show_task
# ABSTRACT
#    Verbosely list a single POSIX thread
# ARGUMENTS
define show_pthread
  show_task_support  _POSIX_Threads_Information $arg0
end
# rerun application
define rer
  set $pc=0x10000
  continue
end
define run
end
define pci
	set $pc=$pc+4
end
define o0
  kill
  O9
end
