gcc 3.4.2 cpu32 patch
Aaron J. Grier
aaron at frye.com
Wed Nov 17 21:57:22 UTC 2004
attached is a patch to gcc 3.4.2 to fix added preprocessor #defines for
cpu32 targets. I've included comments for clarity.
I've successfully built an rtems-m68k cross-compiler for my 68331 target
with this patch. (I was using peter barada's gcc 3.4.2 CVS repository,
but this patch should apply to the trunk version as well.)
Aaron J. Grier | Frye Electronics, Tigard, OR | aaron at frye.com
"Note that many bands' backline amps produce levels exceeding OSHA
standards for industrial facilities. Yet this is considered normal
working conditions for musicians. That's showbiz." -- Scott Dorsey
Index: gcc-3.4.2/gcc/config/m68k/m68k.h
RCS file: /home/cvs/xgcc/gcc-3.4.2/gcc/config/m68k/m68k.h,v
retrieving revision 1.1.1.1
diff -u -r1.1.1.1 m68k.h
--- gcc-3.4.2/gcc/config/m68k/m68k.h 17 Oct 2004 17:54:06 -0000 1.1.1.1
+++ gcc-3.4.2/gcc/config/m68k/m68k.h 11 Nov 2004 01:14:22 -0000
@@ -122,8 +122,10 @@
/* Macros used in the machine description to test the flags. */
/* Compile for a 68020 (not a 68000 or 68010). */
+/* XXX 2004-11-10 <aaron at frye.com>
+ * a true 68020 has bitfield operations, while cpu32 doesn't. */
#define MASK_68020 (1<<0)
-#define TARGET_68020 (target_flags & MASK_68020)
+#define TARGET_68020 ((target_flags & MASK_68020) && (target_flags & MASK_BITFIELD))
/* Compile for a 68030. This does not really make a difference in GCC,
it just enables the __mc68030__ predefine. */
@@ -228,7 +230,14 @@
/* Compile for a CPU32. A 68020 without bitfields is a good
heuristic for a CPU32. */
-#define TARGET_CPU32 (TARGET_68020 && !TARGET_BITFIELD)
+ * yes and no... cpu32 doesn't have a separate interrupt stack pointer,
+ * and has exclusive instructions like bgnd, lpstop, and tbl* . if
+ * support ever gets added in gcc for these instructions (unlikely)
+ * we'll need an exclusive bit to express cpu32-ness, but until then we
+ * can cheat with the following, provided that TARGET_68020 is also
+ * modified as described above. */
+#define TARGET_CPU32 ((target_flags & MASK_68020) && !TARGET_BITFIELD)
/* Is the target a ColdFire? */
#define MASK_COLDFIRE (MASK_5200|MASK_528x|MASK_CFV3|MASK_CFV4)
