Dosfs question..?
Eugeny S. Mints emints at ru.mvista.com
Thu Nov 18 14:08:15 UTC 2004
Hi All,
Really strange return code. unlink() call should transform into
msdos_file_rmnod() routine call. Check whether the msdos routine is
reached if not - the issue somewhere in non-msdos related code (start
from unlink() routine in libcsupport dir).
How do you mount your msdos volume? I suppose you mount to some IMFS
directory (mnt?). My suggestion that the issue is somehow connected to
the mount point.
		Eugeny
Thomas Doerfler wrote:
> Daniel,
> I did a quick check of source codes, I really don't
> know what is going on in your system.
> My idea, what you might do:
> - Either step into the unlink call and find out
> where the error code is set.
> - Or: perform a grep over the libfs source code:
> grep ENOTDIR cpukit/libfs/src/*/*.c
> You will get about 10 results. Set a breakpoint on
> every of these lines. Start your code. And look
> where the breakpoint is hit.
> The rest is analysis then.
> By the way: which string do you pass to the unlink
> call?
> wkr,
> Thomas.
>>Hello.
>>I am running rtems 4.6.2 on a ERC32 using TSIM as simulator enviroment. Am
>>using dosfs on the ramdisk. Everything works fine, as it should, except the
>>removal of files. I try to use the unlink() but it won't accept the file
>>(returns "NOT A DIRECTORY"???). What am I doing wrong. Is maybe the
>>permissions is f**kt up (does dosfs support permissions because I can't
>>change them).
>>Please help me someone or direct me to some documentation about rtems dosfs.
>>Many thanks to Thomas Doerfler for providing to the Rtems community with a
>>functional format function for dosfs.
>>Regards
>>Daniel Gustavsson
> IMD Ingenieurbuero fuer Microcomputertechnik
> Thomas Doerfler           Herbststrasse 8
> D-82178 Puchheim          Germany
> email:    Thomas.Doerfler at imd-systems.de
> PGP public key available at: http://www.imd-
> systems.de/pgp_keys.htm
