Dosfs question..?
Daniel Gustafsson daniel.gustafsson at space.se
Fri Nov 19 08:40:21 UTC 2004
After the exchange of the if-statements I get the error "No such file or
directory instead" if I try to remove a file that are in a directory without
"." or "..".
If I create a directory with "." and ".." and if I unlink a file in this
directory a new error occurs. It is in msdos_find_name_in_fat_file().
It runs assert(ret == bts2rd) where ret = 123 (the filesize) and bts2rd =
512. "Program hangs"
First thought: It tries to read the file as a directory.
NOTE1: The same error uccurs regardles the path (if we are in root or
someware else).
NOTE2: Can someone please provide a link to sparc-rtems-gdb binary. It's not
in /pub/ and I'm am having trouble to build it myself.
Now the file look like this.
msdos_eval.c:
while ((type != MSDOS_NO_MORE_PATH) && (type != MSDOS_INVALID_TOKEN))
  type = msdos_get_token(&pathname[i], token, &len);
  i += len;
  fat_fd = pathloc->node_access;
  switch (type)
         case MSDOS_UP_DIR:
    *  Am I at the root of this mounted filesystem?
	if (pathloc->node_access ==
     		pathloc->mt_entry->mt_fs_root.node_access)
              *  Am I at the root of all filesystems?
           *  XXX: MSDOS is not supposed to be base fs.
         rtems_filesystem_root.node_access)
           break;       /* Throw out the .. in this case */
          else
           newloc = pathloc->mt_entry->mt_point_node;
           *pathloc = newloc;
           rc = fat_file_close(pathloc->mt_entry, fat_fd);
           if (rc != RC_OK)
           goto err;
           rtems_semaphore_release(fs_info->vol_sema);
         return (*pathloc->ops->evalpath_h)(&(pathname[i-len]),
                                          flags, pathloc);
           else
          rc = msdos_find_name(pathloc, token);
          if (rc != RC_OK)
              if (rc == MSDOS_NAME_NOT_FOUND_ERR)
                   errno = ENOENT;
                   rc = -1;
              goto error;
       *  Only a directory can be decended into.
         if (fat_fd->fat_file_type != FAT_DIRECTORY)
           errno = ENOTDIR;
           rc = -1;
           goto error;
       break;
            case MSDOS_NAME:
                    errno = ENOTDIR;
                    rc = -1;
                    goto error;
                 *  Otherwise find the token name in the present location
and
                 * set the node access to the point we have found.
                if (rc != RC_OK)
                        errno = ENOENT;
                        rc = -1;
                    goto error;
                break;
            case MSDOS_NO_MORE_PATH:
            case MSDOS_CURRENT_DIR:
                break;
            case MSDOS_INVALID_TOKEN:
                errno = ENAMETOOLONG;
                rc = -1;
                goto error;
                break;
>-----Original Message-----
>From: Eugeny S. Mints [mailto:emints at ru.mvista.com]
>Sent: Thursday, November 18, 2004 7:02 PM
>To: Thomas Doerfler
>Cc: Daniel Gustafsson; jennifer at oarcorp.com; rtems-users at rtems.com
>Subject: Re: Dosfs question..?
>Thomas,
>Thomas Doerfler wrote:
>> Daniel, Jennifer,
>> this seems like a bug to me. I have looked into "unlink()" code,
>> and currently I really don't understand, why unlink tries to
>> evalute the permissions of the parent of the current directory.
>> When I want to delete the file "/mnt/ramdisk0/testfile.txt", it
>> makes sense to check the permissions of "testfile.txt" and of
>> "/mnt/ramdisk0", because if any of these two is not writable, a
>> delete would be illegal. But why check "/mnt" ?
>it is definitly something wrong some where but it seems to me that
>unlink() just checks permissions for the file you are going to delete
>and the directory which contains this file, i.e. file1 and ramdisk0 ,
>and this seems reasonable.
>Probably the core of the issue is that FAT root dir doesn't
>contain ".."
>entry, I'm thinking over this....
>Oops, seems found the bug in msdos eval code. The handling of
>".." case
>in FAT root dir is right the next operation after the "if" statement
>which returns the error for Daniel.
>Daniel, please try to exchange these two "if"s and see what happen.
>(Unfortunately I have no up-to-date RTEMS sources in the hands).
>	Eugeny
>> Does unlink check the wrong directory? Or does
>> "rtems_filesystem_evalute_parent" check the wrong directory?
>> Currently I don't think that the MSDOS implementation is wrong
>> here, although there is no "." or ".." directory entry in its
>> root.
>> Jennifer, can you help here?
>> wkr,
>> Thomas.
>>>-- In unlink()
>>>Rtems_filesystem_evaluate_path() returns fine.
>>>Rtems_filesystem_evaluate_parent() returns -1.
>>>-- In Rtems_filesystem_evaluate_parent()
>>>msdos_eval_path() (with ".." as path) here we go through
>MSDOS_UP_DIR.
>>>Returns an error (se below).
>>>/DANIEL
>>>>Sent: Thursday, November 18, 2004 4:17 PM
>>>>To: Daniel Gustafsson
>>>>Cc: 'Thomas Doerfler'; rtems-users at rtems.com
>>>>Daniel Gustafsson wrote:
>>>>>Hi.
>>>>>I have debugged the unlink() and the error occurs in
>>>>msdos_eval_path().
>>>>>-- in msdos_eval_path(), line 114
>>>>>switch(type)
>>>>>case MSDOS_UP_DIR:
>>>>>if (fat_fd->fat_file_type != FAT_DIRECTORY)		-->
>>>>>fat_fd->fat_file_type = 5 = RTEMS_FILESYSTEM_MEMORY_FILE = FAT_FILE
>>>>>	errno = ENOTDIR;
>>>>>ERROR!!!
>>>>Well, the unlink(file) should not go through case
>>>>MSDOS_UP_DIR. Please,
>>>>try to
>>>>debug why msdos_get_token() returns MSDOS_UP_DIR type for
>your file1.
>>>>>Steps to mount and create file:
>>>>>1. msdos_format("/dev/ramdisk0", NULL);
>>>>>2. ide_part_table_initialize("/dev/ramdisk0");
>>>>>3. rtems_fs_mount(fs_table, sizeof(...), NULL);
>>>>>fs_table ~ { "/dev/ramdisk0", "/mnt/ramdisk0" , msdos_ops,
>>>>>RTEMS_FILESYSTEM_READ_WRITE, flags, 0 }   --> example
>>>>>4. creat("/mnt/ramdisk0/file1", S_IREAD | S_IWRITE);
>>>>>5. write to file 1
>>>>>6. close file 1
>>>>>7. unlink("/mnt/ramdisk0/file1");
>>>>>Returns "NOT A DIRECTORY"
>>>>>Everything is OK but the unlink.
>>>>>NOTIS: The /mnt/ramdisk0/ doesn't contain "." or "..". If I
>>>>make a sub
>>>>>directory in /mnt/ramdisk0/ it will contain "." and "..".
>>>>>//DANIEL
>>>>>>Sent: Thursday, November 18, 2004 3:08 PM
>>>>>>To: Thomas Doerfler
>>>>>>Cc: Daniel Gustafsson; rtems-users at rtems.com
>>>>>>Hi All,
>>>>>>Really strange return code. unlink() call should transform into
>>>>>>msdos_file_rmnod() routine call. Check whether the msdos
>routine is
>>>>>>reached if not - the issue somewhere in non-msdos related
>>>>code (start
>>>>>>from unlink() routine in libcsupport dir).
>>>>>>How do you mount your msdos volume? I suppose you mount
>to some IMFS
>>>>>>directory (mnt?). My suggestion that the issue is somehow
>>>>connected to
>>>>>>the mount point.
>>>>>>		Eugeny
>>>>>>>Daniel,
>>>>>>>I did a quick check of source codes, I really don't
>>>>>>>know what is going on in your system.
>>>>>>>My idea, what you might do:
>>>>>>>- Either step into the unlink call and find out
>>>>>>>where the error code is set.
>>>>>>>- Or: perform a grep over the libfs source code:
>>>>>>>grep ENOTDIR cpukit/libfs/src/*/*.c
>>>>>>>You will get about 10 results. Set a breakpoint on
>>>>>>>every of these lines. Start your code. And look
>>>>>>>where the breakpoint is hit.
>>>>>>>The rest is analysis then.
>>>>>>>By the way: which string do you pass to the unlink
>>>>>>>call?
>>>>>>>wkr,
>>>>>>>Thomas.
>>>>>>>>Hello.
>>>>>>>>I am running rtems 4.6.2 on a ERC32 using TSIM as simulator
>>>>>>enviroment. Am
>>>>>>>>using dosfs on the ramdisk. Everything works fine, as it
>>>>>>should, except the
>>>>>>>>removal of files. I try to use the unlink() but it won't
>>>>>>accept the file
>>>>>>>>(returns "NOT A DIRECTORY"???). What am I doing wrong.
>Is maybe the
>>>>>>>>permissions is f**kt up (does dosfs support permissions
>>>>>>because I can't
>>>>>>>>change them).
>>>>>>>>Please help me someone or direct me to some documentation
>>>>>>about rtems dosfs.
>>>>>>>>Many thanks to Thomas Doerfler for providing to the Rtems
>>>>>>community with a
>>>>>>>>functional format function for dosfs.
>>>>>>>>Regards
>>>>>>>>Daniel Gustavsson
>>>>>>>IMD Ingenieurbuero fuer Microcomputertechnik
>>>>>>>Thomas Doerfler           Herbststrasse 8
>>>>>>>D-82178 Puchheim          Germany
>>>>>>>email:    Thomas.Doerfler at imd-systems.de
>>>>>>>PGP public key available at: http://www.imd-
>>>>>>>systems.de/pgp_keys.htm
