Help moving BSP to 4.7
Peter Dufault
dufault at hda.com
Mon Nov 29 20:52:57 UTC 2004
I have a BSP I worked on last spring for the Phytec MPC565 that I'll
move to 4.7 for incorporation.
I figure the best way is:
cvs export the current 4.7 top with date "now";
import that snapshot as a vendor branch locally;
add the MPC565 BSP;
provide the resultant patches after checking that they still apply when
I'm done.
Make sense?
Another question - I wanted to use the download helper to see what tool
versions to use. Since I build on
FreeBSD I specified "No tool binaries desired" instead of a host. That
fails:
"There was a problem in running the RTEMS Download Script.
ERROR MESSAGE: Target (powerpc) specified without host
If this problem does not indicate an error in filling out the form and
it persists, please contact webmaster at rtems.com with the following
information:
want_cxx= no
want_ada= no
want_toolsrc= yes
version= snapshot
target= powerpc
host= none
QUERY_STRING=
version=snapshot&target=powerpc&host=none&want_toolsrc=on"
I plugged in Linux to get the source versions used there. Is that
error intentional because you might use different tool versions on
different development hosts, or should "want_toolsrc" work without a
specific development host?
Peter
Peter Dufault
HD Associates, Inc.
