Help moving BSP to 4.7
Joel Sherrill <joel@OARcorp.com>
joel.sherrill at OARcorp.com
Mon Nov 29 21:36:10 UTC 2004
Peter Dufault wrote:
> I have a BSP I worked on last spring for the Phytec MPC565 that I'll
> move to 4.7 for incorporation.
> I figure the best way is:
> cvs export the current 4.7 top with date "now";
> import that snapshot as a vendor branch locally;
> add the MPC565 BSP;
> provide the resultant patches after checking that they still apply when
> I'm done.
> Make sense?
Yes but you could also just do a regular checkout and get it
working. The Makefile and configure.ac are the biggest change.
> Another question - I wanted to use the download helper to see what tool
> versions to use. Since I build on
> FreeBSD I specified "No tool binaries desired" instead of a host. That
> fails:
> "There was a problem in running the RTEMS Download Script.
> ERROR MESSAGE: Target (powerpc) specified without host
> If this problem does not indicate an error in filling out the form and
> it persists, please contact webmaster at rtems.com with the following
> information:
> want_cxx= no
> want_ada= no
> want_toolsrc= yes
> version= snapshot
> target= powerpc
> host= none
> QUERY_STRING= version=snapshot&target=powerpc&host=none&want_toolsrc=on"
> I plugged in Linux to get the source versions used there. Is that error
> intentional because you might use different tool versions on different
> development hosts, or should "want_toolsrc" work without a specific
> development host?
Try Linux and just want source or just go directly to the
ftp site and browse down into the 4.6 tools under linux.
> Peter
> Peter Dufault
> HD Associates, Inc.
joel at OARcorp.com On-Line Applications Research
