Task concepts
Joel Sherrill <joel@OARcorp.com> joel.sherrill at OARcorp.com
Thu Nov 4 18:21:32 UTC 2004
Etienne Fortin wrote:
> I was wondering: Can it cause some trouble to do all my processing,
> tests, etc... In the Init function of the Task? Should my user code go
> somewhere else?
That's not a problem.  I suspect that you are not getting interrupts
for the serial input and the semaphore is not being released to
indicate that data is available.
Eric Norum wrote the code so he can be more precise.
Be sure interrupts are on.
> Etienne Fortin
> Sensio
