Console problem update
Etienne Fortin etienne.fortin at sensio.tv
Fri Nov 5 13:50:18 UTC 2004
Hi Thomas,
Yes, the buffer is empty. But, it shows that at least 1161 characters
were received. After that, termios thinks there's no more data received
or it lost sync or something else.
I said before that my baudrate is really 9630 and not 9600. The computer
is 9600. Do you think that can be the problem?
Etienne
-----Message d'origine-----
De : Thomas Doerfler [mailto:Thomas.Doerfler at imd-systems.de]
Envoyé : 5 novembre, 2004 02:23
À : Etienne Fortin
Objet : RE : RE : Console problem update
Etienne,
from the data you sent, the input and output buffer really is
"empty", (for rawInBuf and rawOutBuf, "Head" and "Tail" have the
same values) but I guess you already saw this.
Which BSP are you using? Is it possible your console driver
interrupt gets stuck, when there is a receive and transmit
interrupt pending at the same time?
wkr,
Thomas.
> Hi Thomas,
> Yes a VERY nasty problem... It must have something to do with my
> comprehension and the way I implemented the console driver... But, I
> was able to make a lot of other things work before (I mean, the
> balance of
> RTEMS) and I got nasty problem with RTEMS before. But that one is
> special. Its so stupid! And I hate to work with transfer protocol. You
> know you'll be able to make it work, you just don't know when...
> Anyway, here's the snapshot of the rtems_termios_tty structure when
> the semaphore get stuck.
> $2 = {forw = 0x0, back = 0x0, refcount = 3, major = 1, minor = 0, isem
> = 436273159, osem = 436273160, cbuf = 0x80d542a4 "}", ccount = 0,
> cindex = 0, column = 0, read_start_column = 0, termios = {c_iflag =
> 9474, c_oflag = 4294967230, c_cflag = 2237, c_lflag = 32768, c_line =
> 0 '\0', c_cc =
"\003\034\177\025\004\n\001\000\021\023\032\000\022\017\027\026\000\000"
> }, vtimeTicks = 100, rawInBuf = {theBuf = 0x80d53a98 "", Head = 1161,
> Tail = 1161, Size = 2048, Semaphore = 436273162},
> rawInBufSemaphoreOptions = 0, rawInBufSemaphoreTimeout = 100,
> rawInBufSemaphoreFirstTimeout = 0, rawInBufDropped = 0, rawOutBuf =
> {theBuf = 0x80d543b0 "ransfer...\r\n\r\nC\006C.\r\nrawInBuf.Size =
> 2048\r\nPress a key to begin t", Head = 17, Tail = 17, Size = 64,
> Semaphore = 436273161}, t_dqlen = 0, rawOutBufState = rob_idle, device
> {firstOpen = 0x17a2 <console_first_open>, lastClose = 0x17ea
> <console_last_close>, pollRead = 0, write = 0x16dc
> <console_interrupt_write>, setAttributes = 0x172c
> <console_set_attributes>, stopRemoteTx = 0x174e
> <console_stop_remote_tx>, startRemoteTx = 0x1778
> <console_start_remote_tx>, outputUsesInterrupts = 1}, flow_ctrl = 512,
> lowwater = 64, highwater = 96, rxTaskId = 0, txTaskId = 0, t_line = 0,
> t_sc = 0x0, tty_snd = {sw_pfn = 0, sw_arg = 0x0}, tty_rcv = {sw_pfn =
0,
> sw_arg = 0x0}, tty_rcvwakeup = 0}
> As you can see, I "hardwired" the rawInBuf to be 2048 characters in
> size. And surprisingly enough, the Head is at offset 1161. This mean
> that I received the first 130 bytes packet (init packet) and some part
> of the first data packet. But for some reason, termios lost sync and
> lost all the next characters, stucking the semaphore and giving me
> headaches :)
> What do you think???
> And by the way, you can't imagine how glad I am to have help from all
> of you on RTEMS forum.
> Etienne Fortin
> Sensio
> Envoyé : 4 novembre, 2004 16:09
> À : Etienne Fortin; rtems-users at rtems.com
> Cc : rtems-users at rtems.com
> Objet : RE : Console problem update
> Etienne,
> can you provide a snapshot of the termios data structures when
> your console input gets stuck? What values do the buffer
> pointers have for the raw input buffer?
> What baud rate are you using currently?
> What happens, if you write a simple application with two tasks,
> one sending a 1K buffer to the console, one receiving it, and
> putting the console into loopback mode (with a nice little wire
> between pin 2 and 3 of your serial connector)? Does it also hand
> in that case?
> You really seem to have a nasty problem there...
> I have been using termios code for machine interfaces back with
> RTEMS version 4.0.0, and I never had similar problems...
> wkr,
> Thomas.
> > I don'T know why I tought that even after releasing the sempahore, I
> > was still stuck in the idle thread. To the contrary! Forcing the
> > release of the semaphore make the task continue to execute code and
I
> > eventually get out of the code with an error (that's ok since the
> > semaphore was forced to be released so no valid data is there
> > waiting)...
> > The question now is why the code is not notified of new characters.
> > Is
> > it possible that the termios code, being designed for "human"
> > interraction (at least I presume), can't cope with sustained binary
> > data transfer and so I lost data and eventually the semaphore is
> > struck waiting for characters that will never come? Is it possible?
> > Etienne Fortin
> > Sensio
> > De : Joel Sherrill <joel at OARcorp.com>
> > [mailto:joel.sherrill at OARcorp.com]
> > Envoyé : 4 novembre, 2004 15:21
> > À : Etienne Fortin
> > Objet : Re: Console problem update
> > Etienne Fortin wrote:
> > > Hello all, its me again, the console guy :)
> > > Little update for the ones that have an interest, or wish to help
> > > me on that matter.
> > Is your interrupt an RTEMS ISR or a raw one directly connected to
> > hardware?  If you do not go through the RTEMS ISR wrapper, you will
> > NEVER schedule out of an interrupt.
> > Also are you sure you are geting the serial port interrupts?
> > > I tricked RTEMS to release the semaphore at each clock tick to
> > > make sure the semaphore was the problem. And surprise surprise! It
> > > still hang in the idle thread!!!!!!!!!
> > > Theory: My task/scheduler/... config is fu***d up. Anyone here
> > > thinks
> > > it can be possible? For what I know of the problem so far, it
seems
> > > that as soon as the idle thread is entered, no other thread ever
> gets
> > > executed... Really seems a config problem to me...
> > > Idea someone?
> > > Etienne Fortin
> > > Sensio
> > Joel Sherrill, Ph.D.             Director of Research & Development
> > joel at OARcorp.com                 On-Line Applications Research
> > Ask me about RTEMS: a free RTOS  Huntsville AL 35805
> >     Support Available             (256) 722-9985
> IMD Ingenieurbuero fuer Microcomputertechnik
> Thomas Doerfler           Herbststrasse 8
> D-82178 Puchheim          Germany
> email:    Thomas.Doerfler at imd-systems.de
> PGP public key available at: http://www.imd- systems.de/pgp_keys.htm
